- Joined
- May 28, 2020
- Messages
- 1,677
- Likes
- 6,608
- Thread Starter
- #301
Not at this time, no. I may revisit towards the middle/end of summer@Buckeye Amps any plans to also offer a Purifi EVAL-1 in a Ghent case?
Do the current cases have vents on the bottom or no? Mine is going into a fairly constrained space so wondering if I should drill holes in the bottom...
I'm keeping inventory of parts simple so I decided to only carry the 252 and 502. The price difference between a 252 and 122 isn't very much, which was another decision to not carry it for my business at this time.Ncore-based amps look intriguing and exciting.
But would it be silly if I were to ask here for an amplifier built using the Hypex NC122MP module?
I'm new to this and learning from this site, but it seems the NC122MP would be plenty of power for my needs (2x125W into 4 ohms).
Is there a reason no one has already asked about an NC122MP here?
Thank you.
It is worth a watch.Mind if I ask which streaming service you watched Greenland on? Watching Total Recall for the first time since I watched it on VHS.
Interesting field, especially now in this pandemic.Immunology
350w per channel at 8ohmsHow many watts/ channel do the 502 modules output into 8 ohms?
I just checked and I could fit one of my 12v relays into the Ghent case. My relay can operate as low as 9v.Can you put in a trigger with the Ghent case. Also, does the 12v trigger require 12v, or is there a range that would allow me to find a device (hopefully a dac) that may output less, such as 5v?
Yes. I recommend the Monoprice male RCA to Male XLR Premier series cable as it is wired correctly and is an all in one solution (no need for an adapter).Hey Buckeye,
This may have been asked, and apologize for what might be an elementary question - looking for a 2 channel 502, most likely. I have 3 preamps I can use but they are all RCA. Can I assume that a properly designed RCA to XLR adapter will work appropriately - or no? Also, another dumb question probably but how do I order one?!
Best,
Daina
As far as ordering, just send me a message or email.
Not exactly qualified to answer here but... pretty sure use of an adapter is not recommended. Just get the male rca to male xlr cable at enough length to connect from avr/preamp to the buckeye amp.Ok, that's closer, but I would need a female RCA to connect my RCA cables to the adapter. Sweetwater sells a nice Hosa branded one. Also, I see where I can message you, but I don't see a straight up email address.
Thanks!
Daina
