- Joined
- Feb 23, 2016
- Messages
- 20,914
- Likes
- 37,975
There are 176 and 192 khz recordings of cymbal strikes with microphones from Earthworks with the bandwidth to pick it all up.Is'nt there a close up O scope time trace of a "high" speed real music transient using a transducer that can capture it? Like drum rim shot, metal stick on cymbal, or pick on string? Then A>D>A and compare. Scope all the way?
I have taken those and down-sampled them or alternatively used a low pass filter at the native sampling rate. The bit above 20 khz (which btw is much less than you think) is not heard. You can't differentiate if it is present or filtered out by listening if you are doing so blind.
Like I've mentioned before, if this far down the road we are still unsure if the extra bandwidth helps or not there are only two possible answers. It might help a small amount for a few people rarely, and the difference is nearly insignificant or it makes no difference to anyone. Recording with 20 khz bandwidth is 99% sufficient or 100 % sufficient. We aren't talking big differences either way. If it makes you happy use 88.2 or 96 khz sampling. Beyond that is only fantasy at best. At worst those more elevated rates will sometimes cause problems you otherwise don't have.
