- Joined
- Mar 1, 2020
- Messages
- 479
- Likes
- 853
Hi,
I am thinking of replacing my ceiling speakers because I suspect that they might be the reason for, sometimes, not so convincing immersive surround experience.
They are Monitor Audio Pro-65, the cheapest option I could find then, thinking they don't need to be high end speakers for few effects up there, with 86 db sensitivity, 75hz-20hz (on paper, but Audyssey wants to cross them at 100 or 120hz) and 101 dBA spl max.
They have an ability to direct the tweeter to listening position.
My main speakers are much bigger and more powerfull with exotic drivers and there is no way to replicate something similar in the ceiling, but I was thinking if I get speakers with relatively flat FR, slightly better bass response and higher SPL ( aka more expensive), maybe height level will be more pronounced and similar to bed channels...
Since KEF speakers with Uni-Q drivers have a decent FR, tested well here and are considered flat and neutral, I was thinking of that option. You can't point their tweeter, though! But they claim wide dispersion, so I might not need pointed tweeters.
Or I just buy more expensive, more powerfull monitor audio... or don't change at all (highly unlikely, because I like experimenting with speakers).
There aren't many options in my country, that is why I listed only those two brands. There is Dali also, but... I don't know.
There is very little measurement available of custom install, especially ceiling speakers. At least, what I could find...
I thank you for your thoughts on this.
