Center for the ELAC DBR-62? (for home theater)
SynthesisCinema
Sure, but it's trash.
Not likely if listeners sit fairly center to it and not further on the sides where the issues arise.
Third DBR-62 vs. DCR-52 if just one listener dead centre? Wouldn`t you gain some advantage sharing the load to two slightly smaller drivers also?
2x 5,25" vs. 1x 6,5"? And 1db bump in sensitivity.
Dougey_Jones
I highly doubt it’s more “trash” than the outcome would be if OP bought a center channel from a completely different brand with completely different drivers and crossovers, like some in here are suggesting.
sword
@Sancus So what would be the easy way then? Start with an Emotiva center and find something to match it? Or try to match a center to the DBR-62? I'm not sure these would play well together. I remember reading that the ELAC has a cloth dome tweeter and the c2 has a folded ribbon tweeter and thus could have very different sounds, though I'm not sure how that plays into dispersion. I'm still learning audio. Browsing this forum has been eye-opening.
Is there a good combination of L/R/C that you guys commonly recommend here? Or should I explore the idea of getting 3 DBR-62's and just sticking one under my tv? A little below ear level albeit.
Don't worry about trying to "match" the speakers. Unless you listen to a lot of multi-channel music, any good center will work. I know this from experience. It's surprising how everything blends together once proper levels and distances are used in an AVR.
sword
Have you ever tried it? There is a thread on AVSforum with links to 80+ users who posted their positive experiences using a good center and different brand fronts. Unless you listen to a lot of multi-channel music, it doesn't matter very much with a modern home theater AVR.
The DCR-52 probably isn't trash, but it's still a 2-way MTM design, which will have narrow horizontal dispersion and comb filtering. For most people that just sit dead center, that may not be an issue.
sword
The Monprice THX-365C center is a good deal right now at Target.com for $400 plus a free 30-day return at any Target store. I just set one up this weekend with JBL Studio 580 fronts and it sounds great. Good sensitivity, 3-way design, and it playes loud without breaking a sweat.
sword
Yes, some are fine. The rule of thumb is basically that 2-way MTM(midwoofer-tweeter-midwoofer) centers are always pretty bad. Basic 3-way centers like the Emotiva C1+ or Monoprice THX-365C are usually good.
The Emotiva C2+ is a weird one since it has two midranges and no one has measured it. I don't know if it's good or not.
The C2+ was reviewed by Erin. It's good for output, but has a couple other issues. It's also huge in my opinion. The Emotiva C1+ would probably be good.
Sancus
Matching those things is irrelevant compared to matching dispersion, and those centers don't even have anything remotely like matching dispersion with any normal 2-way, regardless of brand.
People keep clinging to this "off-axis doesn't matter" thing but it contradicts all speaker research so.... I'm going to keep saying off-axis does matter, whether or not it's a center.
If you have a very limited budget and you are stuck with a 2-way MTM center then that's fine, you did your best. But pretending it's good compared to other options is another story. This forum, last I checked, is about finding the best options, not merely the "ok" ones and then repeating to ourselves over and over how "ok" is good enough.
