JBL Conceal C83 Invisible Speaker Review
Rate this speaker: (do not need to be an owner to do so)
    Votes: 90 67.2%
    Votes: 36 26.9%
    Votes: 7 5.2%
    Votes: 1 0.7%
617
Somerville, MA
I've often come across speakers like this when I was building high-end retail stores like Chanel and Dior. Those designers didn't want to see fire strobes, let alone speakers. They were fine for background music applications.
How did you deal with fire strobes/light sensors and so on? I've mostly seen ceiling systems with slats that you can hide things in but there's something special about a flat white ceiling.
simnick
Seattle
Dear god, can someone please make designer residential (and commercial) smoke/fire equipment? Totally messing up our vibe in the new house. Vents, designer option. Speakers, designer option (but maybe not a good sounding). Lights, designer option. Smoke? Good luck. And recessing them is against most fire code.
The architects were typically against mounting fire strobes on walls which were more often than not lacquer or millwork panels. Ceiling mounted strobes were preferred, but they would have to always align with nearby lights or other equipment. Access doors for above ceiling equipment were grudgingly allowed, but they of course would have to be the taped-in GFRG variety and of course they would have to be aligned somehow--while still serving their purpose. These speakers were good in that they didn't have to align with anything. They are invisible, after all. Except, of course, if you have a lousy taper.
Reactions: 617
617
Somerville, MA
I have a friend who does high end venetian plaster for retain spaces like this, I wonder how loud you'd need to run these to hear anything over that.
GXAlan
This is an interesting alternative for the “no visible speakers” approach. Hide it all in the sofa with fabric specific tuning!
Lovesac x Harman Kardon
Head_Unit
While it probably sounds okay for the intended purpose, $1100 is ridiculously overpriced for a single speaker.
Small sales quantity. As @Matt_Holland points out there have been some of these. The oldest AFAIK is the Bertagni (because B.E.S.T. became Sound Advance got bought by Sonance). Most of the business was large panels designed to replace drop ceiling tiles, even to the extent of printing fake hole patterns. Really wide dispersion. Also usable as a screen with quite good sound. Good enough for The Three Tenors to use for PA (Placido Domingo was a B.E.S.T. investor). These were in my opinion DML drivers before NXT was a thing-totally different "cut and try" engineering approach vs. NXT's "military technology repurposed for simulation." With a big panel clamped around the edge excursion is reduced so should not crack the paint...unless you turn it up to 11!
This is like the little Bose cubes: prioritizing invisibility. And, like those cubes, when listened to standalone can sound much better than you'd expect from measurements. Definitely the big B.E.S.T panels could sound really nice; I never heard a good setup of the "Invisible" one to be judging that. As DML speakers the time response would be different from conventional speakers (though it's been a LONG time and I don't remember exactly how).
