CES 2017: Moon by Simaudio
Our canadian friends were back:
I have seen large amplifiers before but never seen one this large that was class AB. This is Boulder class size with their own branded capacitors and such. And while not as stuffed as a Boulder class A amp, it was still massive.
I like the way they translate the watts into Horse Power in their spec! Pretty appropriate I think.
DonH56
Monument, CO
Glad to see the caps were rated to 105 degC, but if I did the math rightly then 888 W into 8 ohms means about +/-120 V min rail voltage (really probably >+/-125 V) so those 100 V caps must be in series-parallel... Machining to 1 mil is pretty impressive.
RayDunzl
Central Scrutinizer
Riverview FL
Notice the chromed transformer covers
They may have missed a marketing angle:
"Chromium is remarkable for its magnetic properties: it is the only elemental solid which shows antiferromagnetic ordering at room temperature (and below). Above 38 °C, it changes to paramagnetic."
Even if that doesn't mean anything it sounds good.
Does it have differential output? Seems to.
"Power Output Capable of Over 746W RMS (1 Horsepower) @ 1kHz x 2 Fully Differential Channels @ 8 Ohms"
Then 60V rails would do, wouldn't they? When the + is driven to +60, the negative is -60 (not ground), giving the 120V across the load.
DonH56
Monument, CO
That could be (i.e. effectively bridged output amps) -- I did not read that. The symmetric modules and such and fact that it is mono seems an indicator... Your turn to correct my mis-thoughts; too many other things going on right now (far removed from audio stuff).
RayDunzl
Central Scrutinizer
Riverview FL
Usually you're so "right" and "complete" it's difficult to add anything of consequence.
I wouldn't have caught it except my own amps are differential and I had to think about the consequences of that sometime in the past.
