Chipset tpa3116 or Infineon ma12070
godsmack50
Hi, I would like to buy a small SMSL amp , the two models that interest me are the SMSL A50 with the tpa3116 chipset and the SMSL SA300 with the Infineon ma12070 chipset , I would like you to choose between these two amps the one that will be the warmest possible , with the most round bass possible !!! For you which one would correspond the best to my research between these two amps please ? Thanks
  • smsl-sa300-amplificateur-class-d-usb-bluetooth-50-aptx-subwoofer-ma12070-2x80w-4-ohm-32bit-384...jpg
Doodski
Hi, I would like to buy a small SMSL amp, the two models that interest me are the SMSL A50 with the tpa3116 chipset and the SMSL SA300 with the Infineon ma12070 chipset, I would like you to choose between these two amps the one that will be the warmest possible, with the most round bass possible !!! For you which one would correspond the best to my research between these two amps please ? Thanks
Proper good amps do not induce a warm or more bassy sound.
godsmack50
godsmack50
yes but precisely , I don't like neutral amps , I like amps that have a sound signature as warm as possible, so !!!
Doodski
yes but precisely , I don't like neutral amps , I have amps that have a sound signature as warm as possible, so !!!
If you want a specific sound then why are you buying cheap little amps?
godsmack50
godsmack50
Because it's an amp I want to use on my pc , and I want a small amp that doesn't take up space under 150 dollars , and with the warmest sound possible !!!
Doodski
If you want warm and distorted then buy a tube amp.
godsmack50
godsmack50
That's not my question , my question is, between these two amps, which one would have the warmest sound please ? I don't ask anything else
Wolf11Man
None of the chips is warm. Sorry. If you want warm, look for a small amp with such a chip that has a tube integrated as a "magic sound improver".
The tube get's warm, glows, you look at it, listen and the sound get's warm. Quite simple. Works a charm!
Doodski
Neither sounds warm. They are IC design amps with cheap little amp ICs.
godsmack50
godsmack50
It is still not my question , I ask again, between these two ampli which would have the warmest sound ? my question is simple.
godsmack50
godsmack50
I already know that there are much warmer amps than the ones I propose , but I just want to know between these two amps which one would sound warmer ? I don't want to know anything else, thanks
Doodski
So these two amps sound exactly the same to you ?
Yes, they are the same sounding. Anybody tells you otherwise is full of it. They are comparable to buying a car audio head unit or a cheap blaster. Not high end and having a sound. Amps with a sound are expensive because they have a sound and tube amp will definitely give you a sound because it is inherent in the design most of the time.
Doodski
... and I commend you for patiently asking multiple times but there is no good news to give you.
godsmack50
godsmack50
However I often read that different chipsets could not have the same sound, too bad, so one or the other will have exactly the same sound despite their different chipset ?
Doodski
Yes, the difference is miniscule. if you want a warm sound look to your speakers. They will determine the sound type. Selecting a amp while looking for warmth is not the way to go with solid state amps. Solid state amps are very similar if operating within their limits.
godsmack50
godsmack50
And I suspect that with this kind of amp I will not have the sound of a vintage amp Marantz for example!!! lol
godsmack50
godsmack50
My speakers are DAVIS ACOUSTICS MIA 20 , a French brand .
Doodski
Nope a vintage Marantz is in a different class. I've had a vintage Marantz and it sounded good. But there are vintage Marantz one should stay away from unless they are collectors of Marantz. The quasi-complimentary design has issues and that is the one to stay away from.
