The power differences between the X8500H, X6700H, X4700H and X3700H are about 1dB. If the requirement is for an AVR with only the internal amplifiers used, and with the number of power amplifiers that the X3700H or X4700H provide, then the lower price products provide a little cleaner power with about 1% less output. While the preamps of the X8500H and X6700H are the cleanest in the group, the good (actually a little disappointing), but not great distortion performance of the power amplifier channels is the limiting factor in the X8500H and X6700H power amplifier performance. There is little to no reason in this use case of 100% internal power amplifier channels, to choose the X6700H or X8500H unless based on features important to a specific user. This is good news. It means that there are low cost options with excellent performance.
If more power amplifier channels are required than the X3700H or X4700H provide then of course the X6700H with 11 channels, and the X8500 with 13 channels are the obvious choices.
The real advantage of the X8500H is when the preamp outputs will be used, especially if a mix of preamp outputs and internal power amplifier channels are used. The ability to disconnect the preamps from the power amplifiers on a channel-by-channel basis is a significant advantage in this case. Purchase of say a three channel power amplifier for the L/C/R channels and driving it with clean preamp outputs while still being able to use all of the good internal amplifiers, is a very cost effective, as well a very good performing solution. External power for only a few channels is clearly much more cost effective then using external power amplifiers for all channels.
For preamp-only use, the preamp outputs of the X8500H are a bit cleaner, which is nice. The X6700H is still excellent in the world of AVR’s. X3700H and X4700H are very good. Little is given up with the budget choices. It is very unfortunate that Marantz really doesn't enter much into consideration at present with its non-standard reconstruction filters and HDAM distortion issues. Amir’s future measurements at ASR over the coming months of the new generation of Marantz AVR’s and AVP’s will reveal if this situation has changed.
As with the power amplifiers, if only the X8500H or X6700H have enough preamp channels to meet requirements then they are the obvious choice. These two units provide the best measured preamp performance as well, so there is no compromise.
The measurements of upper level Denon AVR’s in ASR have provided some amazingly good news for a wide variety of potential AVP and AVR purchasers.
