Choosing Unbalanced RCA Audio Cables for Home Use: What Really Matters? - Shielding & Directionality Questions
RayDunzl
Central Scrutinizer
Riverview FL
As I said, the far end was open.
Ooh. More reading comprehension faults here.
I suspect all cables will work equally well if they aren't connected.
Carry on!
SIY
Alfred, NY
Without seeing the setup, I can make a pretty good guess about what's being seen here. The open end gives it away.
dc655321
ohhhhh - suspense!
From the Amazon product description:
SOLID LONG-GRAIN COPPER (LGC) CONDUCTORS: Solid conductors eliminate strand-interaction distortion. Evergreen’s solid Long-Grain Copper allows a smoother and clearer sound than cables using regular OFHC (Oxygen-Free High-Conductivity) copper. OFHC is a general metal industry specification regarding “loss” without any concern for distortion. LGC has fewer oxides within the conducting material, less impurities, less grain boundaries, and definitively better performance.
FOAMED-POLYETHYLENE INSULATION: Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then released as distortion. Tower uses air-filled Foamed-Polyethylene Insulation on both conductors because air absorbs next to no energy and Polyethylene is low-loss and has a benign distortion profile. Thanks to all the air in Foamed-PE, it causes much less of the out-of-focus effect common to other materials.
METAL-LAYER NOISE-DISSIPATION SYSTEM (NDS): 100% shield coverage is easy. Preventing captured RF Interference from modulating the equipment’s ground reference requires AQ’s Noise-Dissipation System. Noise-Dissipation System prevents a significant amount of RFI from reaching the equipment’s ground plane.
Are the differences in reflections due to the asymmetric shielding coverage (aka "Metal-Layer Noise-Dissipation System" :facepalm:)?
Sal1950
The Chicago Crusher
Central Fl
Boromirka
Great that i found this thread by accident. Which cable should i use afterall? I am more confused now.
Edit: can someone suggest some brands or models that can be bought in EU, please? My setup will be Khadas Board + Atom, so i am not in need of really expensive cable
SIY
Alfred, NY
ohhhhh - suspense!
Nope, you'd see the same differences with any unterminated cable at that time scale unless you REALLY carefully controlled physical positioning, which in swapping directions, I'll bet was not done. Terminate it properly and the positioning won't be nearly as critical.
mansr
Hampshire
The differences are due to the shield being connected in the far end only. Attaching it at both ends results in normal behaviour.
SIY
Alfred, NY
It would have made things clearer if you had diagrammed your test setup...
mansr
Hampshire
Nonsense. A cheap RG-58 or RG-59 coax is quite insensitive to positioning. The AQ cable does depend on position, but the asymmetry is still clear.
SIY
Alfred, NY
Terminated, sure. But if the far end is unterminated, the positioning for measuring reflections on the nanosecond scale is indeed critical. Like I said, you need to diagram test setups in order to avoid ambiguity.
Boromirka
Do AudioQuest Tower and AudioQuest Evegreen have a good soldering? Are they good in general?
Or should i look for other brand?
SIY
Alfred, NY
T coupling on the scope input, which is set to 1 MΩ.
AFG output (50 Ω) to T with short RG-58.
AQ cable on other side of T.
Yes, clearer, thank you!
How do you attach the shield at both ends?
