CHORD Mojo 2 Review (Portable DAC & HP Amp)
Rate this product:
    Votes: 11 3.2%
    Votes: 35 10.1%
  • 3. Fine (happy panther
    Votes: 145 41.8%
    Votes: 156 45.0%
This is a review and detailed measurements of the CHORD Mojo 2 portable, battery operated stereo DAC and headphone amplifier. It is on kind loan from a member and costs US $799.
The Mojo 2 is solidly built. While I am definitely not a fan of multi-color interface, the buttons feel better in this model and some of the lights kind of make sense (e.g. showing volume level).
Input interfaces are crammed into one side but it is workable and I appreciate having dual USB input jack options (USB-C and Micro-USB):
On the other side there are two headphone jacks:
I am unclear why in this day and age of personalized music consumption, one would want to share the device with another person listening to the same content.
I charged the unit and tested it with USB input and the left headphone jack out.
Chord Mojo 2 DAC Measurements
Let's treat the unit as a DAC by adjusting the output to 2 volts and run our tests:
This would be an excellent performance for a desktop DAC and superb for a portable one:
You get slightly better performance if you allow the output voltage to go up higher:
Dynamic range is again, competitive for desktop DAC and excellent for a portable one:
Claim to fame of Chord DACs is their high-tap reconstruction filters. I was pleased to see it deliver the best performance I have seen in just about any DAC:
You get the full audio band to nearly 22 kHz and then excellent attenuation. This is what I hope every DAC chip/company implements instead of the lazy ones we see where cut off is at 24 kHz.
Linearity is excellent:
Multitone shows impressively low distortion levels:
IMD distortion test shows very well behaved response, again rivaling good desktop products:
Chord Mojo2 Measurements IMD Distortion Portable DAC Headphone Amplifier.png
Jitter was a bit disappointing given how good the device is otherwise:
But not remotely an audible issue.
Sweeping frequencies we see a slight rise in distortion with frequency:
Chord Mojo2 Measurements THD+N vs Frequency Portable DAC Headphone Amplifier.png
We can confirm that by running a spectrum analysis:
Chord Mojo 2 Headphone Amplifier
We can let the device loose by maxing its volume and see how well it produces power, starting with 300 ohm load:
Chord Mojo 2 Measurements Power 300 ohm Portable DAC Headphone Amplifier.png
My threshold for desktop products is 100 milliwatts and this is close. Noise and distortion are impressively low. Switching to 32 ohm load we get similar results:
Checking for noise at tough 50 mv shows middling performance:
So careful with ultra sensitive IEMs.
Chord Mojo 2 Listening Tests
As usual, I started with my Sennheiser HD-650 headphone to test high impedance response. Sound was wonderful and there was enough volume/dynamics to bring out the bass out of this headphone. Switching to Drop Ether CX, there was even more volume available before slight distortion set in at max volume. I then plugged in the torcher test: Dan Clark Stealth which is my everyday headphone. Volume dropped quite a bit. Increasing it using the controls on Mojo 2 created static proportional to how much I cranked it up. Unless you are happy with pretty soft volume, it is not usable with Stealth (not that it would be in portable class).
Company is know for overdesigning its reconstruction filters. I see no benefit in that but the implement of Mojo 2 has definitely benefited from excellent engineering and closed loop (with measurement) design. Even as a desktop DAC it would be an excellent product. As a portable battery operated one, I think but I suspect it is the best I have tested.
It is my pleasure to recommend the CHORD Mojo 2. Yes, the price is up there but at least you get great objective performance to go with it.
_thelaughingman
Planar's would suffer from lack of current, but pretty impressive product.
Kaiju
I think it cost 40% more expensive with this performance.
Jimbob54
Good review of a (technically) great product.
As I understand it, the main selling point of this over the mojo 1 is the DSP function which Mr Watts claims to be the best thing since sliced bread. It would be nice if at some point it was possible to test that vs an upstream solution (say Roon on a pc) and other on device implementations (say on the rme adi 2 dac and maybe the Qudelix 5k). No idea how the test would work in terms of measurements.
Now let's wait for the flood of posters claiming this is the best sounding product known to man.
Music1969
This is Rob Watts main headphones at the moment.
Awww maybe you and Rob can finally hug it out at the next big HiFi show :D
Jmudrick
Why would I want this rather than a DAP with a screen and android operating system?
I think it depends on what you are driving. With easy to drive IEMs an LG phone will suffice. I don't know the use of case for portability with hard to drive cans but I guess it is there.
And he uses it with Mojo 2? If so, he must want his music at low volume or is not sensitive to distortion!
Zensō
California
Yeah, I can’t really imagine walking around in public wearing a DCA Stealth and carrying a Mojo. That said, quite a few people used the original Mojo as both a mobile and desktop unit, I suspect it will be the same for this one.
I don't like DAPs because they are bigger, heavier and have UI that I don't like. With a device like this, you can use your phone with its familiar interface and many choices and then get optimal output power to drive headphones.
AudioTodd
While I’m sure some will sneer at this question, is there significant phase shift at high frequencies to be expected with the sharp filter?
Garrincha
Since there exist for a already several years excellent and pretty cheap dongles, I don't understood anymore neither the use case for DAPs nor bulky portable battery powered dacs/heaphone amps (what is the supposed source in this case?). Everybody has a smart phone, so get an almost SOTA dongle for $100 and you are done. What is the point?
