Chord quest, Vs Rme adi-2 dac fs + tap count.
Gurra1980
Hi everyone my first post!
I have a Chord Quest that I'm happy with, but I'm looking for an eq solution for my problematic room. I thought about testing the highly acclaimed Rme Dac. I have seen most reviews on YouTube, most seem to think qutest is the best, but only by a slight margin. The general consensus is that the qutest is slightly smoother and Rme is crisp and sharp. One reviewer believes that it is because of the much higher tap count of the chord. And also said that it can't be equlized away because it's not about frequency but probably because of tap count.
I saw Amir write this in the end of his review of the chord: I wonder how good of a DAC Rob could design using an off-the-shelf DAC chip. Likely would be just as good and cost a lot less....
So my last question would be, is there any science saying that a higher tap count is not necessary? Because it makes a lot of sense to have a higher count.
Purité Audio
Industry Insider
Barrowmaster
London
None whatsoever, what we have is Rob stating that increased tap length equals better SQ but absolutely no substantiation.
I strongly suspect you would not be able to tell the two dacs apart, comparing unsighted.
G
Gurra1980
That's what I hope for, but I'm interested in the science behind your statement, if there is a company that's basing all its products on a certain technique, then I think it's worth a solid explanation if you call it all bullshit. After all it's a very solid DAC with top notch measurements.
Purité Audio
Industry Insider
Barrowmaster
London
Amir has measured at least two Chord dacs, the measurements are excellent, but in the contemporary audio market that apparently isn’t enough , you need a USP, hence the tap length, Rob/Chord have never published any data/testing which substantiates their claim and there is nothing extraordinary in their measurements.
Compare for yourself, without knowing which you are listening to.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
It's not calling it bullshit, it's saying that whatever it does won't change the way the music sounds.
As stated above, they are generally respected in terms of engineering. What is missing is any controlled testing that demonstrates any audible difference or preference between it any competent run of the mill DAC.
G
Gurra1980
Well if he is saying that it does not do what they claim, then it is calling their claims bullshit.
Well well, I'm just interested to know if someone can explain scientifically why it would not make a difference sonically? You know I would like to have a DAC as good as the qutest but with all the features and the Rme.
What better place to ask these questions than on Audioscience forums? :)
G
Gurra1980
Well I think I might order an Rme, and let my girlfriend switch DACs so I can test. Though she starts getting a little annoyed with all my blind testing at home
Racheski
Chicago
To move this thread along because I find it interesting, here is what Rob Watts claims:
What I have done is to make no assumptions about whether something makes a difference to the sound unless I actually do a listening test. And listening to increasing tap lengths always improves the sound quality. With Dave, I am at 164,000 taps, and I know that that is not the end of it and that further improvements are possible.
https://www.the-ear.net/how-to/rob-watts-chord-mojo-tech
I think ASR would call BS on listening tests always revealing that more taps equals improved SQ.
BDWoody
Chief Cat Herder
Moderator
For people who do their listening impressions without controls, it likely will sound better. They paid for it or designed it to after all.
Yeah...that's BS...i stand corrected.
Thing is, I'll bet he believes it. Doesn't mean they aren't well, or interestingly engineered, just means the claims of sonic superiority are anecdotal.
G
Gurra1980
Hm, so I guess then we don't really know, his claims are bold, but we have no solid proof yet that it's bs. It would be interesting if someone could do a controlled blind test, between maybe Rme, topping d90 and a higher end chord DAC. Maybe I can film my own little blind test when I get the Rme.
Racheski
Chicago
We have no proof that it is true either.
G
Gurra1980
The error with a normal number of taps is already far smaller than anyone can possibly hear. Making it more inaudible is pointless.
Ok, that's what I thought. How does taps differ from resolution? And can you point me in some direction to where I can find info about taps and what number is considered to be audible or not?
Btw I don't even think I could pass a blind test between 320kbps MP3 and cd. So if this somehow relates to that then I don't think I could hear it.
Phorize
U.K
You seem to be saying that an unsubstantiated but falsifiable claim about Chords fpga requires rebutting. That’s a logical error; his dacs don’t measure any better than well implemented of the shelf dac chips costing considerably less to the end user. It’s Rob Watts that has to support his own claim with facts and so far he has failed.
G
Gurra1980
The RME DAC only has limited EQ capabilities, so might not be enough to fix your room issues anyway.
The big issue is that my room has extreme bass dips in frequency at my listening position. It might help, at least Moore than my qutest.
tw99
West Berkshire, UK
Room EQ is better at fixing peaks than filling dips. Personally I'd start by measuring the room using REW and a calibrated microphone, and then see what problems actually need fixing, rather than just jumping to a possible solution.
DSJR
Suffolk Coastal, UK
Just to put another boot in. I think audiophiles think commercial music recordings are actually better than they are and tend to latch on one aspect at the expense of the rest of the music mix as heard. You seemingly improve one aspect and the rest goes out the window. Just a thought, I'm still reeling/fuming over an M-Scaler dem I was at, hearing a difference with it switched in but feeling the volume might have been changed - apparently it is when switched in and with no correction for it...
G
Gurra1980
Well, of course he needs to provide proof, but so does the one saying he is making nonsensical claims. How can it be illogical to demand proof from booth sides? If one claimes a difference and one not, then booth need proof. I'm pretty new to measurements so I try to understand them, but I for one are just as critical to measurements as to random reviews. One area in specific has made me think this way, and that is tube amps, to my ears they sound better, more real, and this has always been the case for me, long before I was that in to audio, but according to measurements (if you don't understand them) tube amps would sound shit.
Ok, so the measurements of the DAC tells there is no difference at all, which measurement would be off when it comes to insufficient taps? And might it not be a measurement that is not performed? Or does not exist?
I'm sorry, but I just want to know, if Rob watts was a nobody then I might not have cared, but Chord is a reputable brand that has a lot of followers. Yes there are bullshit brands like nordost and transparent that has a cult following but, I think this is more complicated than cable measurements.
