Close-back setup
Ole_S
Hello guys,
Thanks for the help putting together my open-back setup. I am very thankful to you.
Can you also help put together a close-back setup that I can use when I'm not at home?
I mostly listen to classical and instrumental music.
I'm considering these close-back headphones:
  • DAN CLARK AUDIO AEON 2 NOIRE
  • Meze 109 pro
  • AUDEZE LCD-2 CLASSIC CLOSED
If you have any better models in this price range, you are very welcome to provide input :)
Looking forward hearing from you.
Kindly regards,
Ole S.
solderdude
The Neitherlands
Meze 109 pro is open back, the Lyric is closed back.
It is on the 'warmer' side of things.
You may have meant the '99' model.
Drop AEON X Closed
LCD-XC (later version)
Also consider Austrian Audio Hi-X60 (neutral)
Focal Celestee (also warmer side).
O
Ole_S
Drop AEON X Closed
Thank you for input
O
Ole_S
I might just go with the
AKG K371 for close-back.
Snoopy
I got the Aeon 2 Noire and it's a very good headphone that doesn't really require PEQ to sound good. The earcups are very spacious and the headphone is comfortable.
I use it for movies and TV shows.
O
Ole_S
Aeon 2 Noire seems to be very good. And gets tons og great reviews.
O
Ole_S
Maybe
Beyerdynamic DT 770 PRO - 250 Ohm is too analytic.
ThatGuyYouKnow
The Noire is hard to beat for orchestral music, both close-miked and spacious recordings. It passed my rigorous Jerry Goldsmith test like no other headphone straight out of the box.
O
Ole_S
Great input.
Thanks.
O
Ole_S
Which AMP/DAC do you use for Aeon 2 Noire?
O
Ole_S
Do you have recommendation for AMP/DAC?
Snoopy
I have 2 setups.. Cambridge CXN V2 with Singxer SA-1.
And SMSL D300 with SMSL SP400.
Both headphone amps are plenty powerful even with PEQ, Convolution filters or headroom in roon.
MrNice13
Switzerland
Maybe
80 ohms one are less analytic seriously good set of cans forget the akg... better get the senns 280 pro
MrNice13
Switzerland
or Samson 850 Sound so good with good pads
O
Ole_S
This one?
Snoopy
Strange how it went from a bunch of really great headphones to the low end stuff again.
