Close-back setup
solderdude
The Neitherlands
But I have UPS Audio Player Pro for EQ.
And I guess several transportable AMP/DAC plays better and are more powerful than K5. I we do not think of the EQ
As said, I merely mentioned features that it has that others may not have. When you do not use the features look for something you need.
It stands out because it is small, portable and desktop and has EQ options. That's it.
O
Ole_S
Do you buy a new amp/dac each time you buy new headphones?
I guess not.
solderdude
The Neitherlands
I never bought any amp but did buy an E30 and UMC 204HD but have bought well over 50 headphones in the last few years.:)
O
Ole_S
Now I get curios.
Topping E30 is nice. I know that.
But UMC 204HD ?
solderdude
The Neitherlands
It serves a purpose and for that purpose it is all I need.
Needless to say I am DAC-deaf as well. :)
O
Ole_S
Regarding EQ and Macbook:
UPS Audio Player Pro is just for Android, as I know.
Therefore the K5 might be a great option anyway.
solderdude
The Neitherlands
DAC-deaf?
I can't hear any differences between DAC's using a proper reconstruction filter when level matched despite thousands of people claiming they do.
I must be deaf for those DAC 'differences' :) so ... DAC deaf.
staticV3
Basically similar to 99.
"Basically similar" as long as you ignore the 11dB difference in bass response:
¯\_(ツ)_/¯
