Lupin
- Joined
- Feb 11, 2021
- Messages
- 589
- Likes
- 981
Which DACs do PCM 384 and PCM 768 over S/PDIF?Plenty of dacs do 384 and 768 khz.
All modern DACs do PCM 384/786 over USB not sure I know any that do it over S/PDIF.
No longer use Roon but I'll see what I can doInteresting, would you please share with us the results?
Thanks,
I've encountered devices that can't send and devices that can't receive. Never a cable that can't.Based on your experience, in digital audio, if a coax/optical cable will be not able to handle a specified sample rate let's say 192kHz, the sound will be interrupted OR will be still audible but the data will be down-sampled at the maximum sample rate supported by that cable?
It's true that once I've received an answer regarding the coax cables but meanwhile reading further, it looks like the things could be in other way.
OK. So this is Windows upsampling amazon HD to 192, sending via USB to my streamer which then has an optical (and coax) output. Optical to m500. Plays 192 fine. This was some old QED cable. I've had no problems with amazon basics and other cheapos.Based on your experience, in digital audio, if a coax/optical cable will be not able to handle a specified sample rate let's say 192kHz, the sound will be interrupted OR will be still audible but the data will be down-sampled at the maximum sample rate supported by that cable?
"As I sharted here, I fully........" ;>) ;>)Just for your reference,,,
Although discontinued quite regretfully, Onkyo DAC-1000 (launched in 2010) is/was really amazing DAC featuring two S/PDIF Coaxial IN (max. 192 kHz), two S/PDIF optical IN (max. 96 kHz), one S/PDIF optical OUT (max 96 kHz), one AES/EBU digital IN (max 192 kHz), USB digital IN (max. 192 kHz), XLR balanced stereo analog OUT and RCA unbalanced stereo analog OUT; the sound quality is still really wonderful. I actually keep one DAC-1000(S), and it works perfectly fine up to 192 kHz 32 bit DAC processing;
https://www.jp.onkyo.com/audiovisual/audiocompornent/accessories/dac1000/index.htm
https://www.jp.onkyo.com/audiovisual/purecomponents/accessories/dac1000/spec.htm
https://www.amazon.com/Onkyo-DC-Converter-DAC-1000S-Japan/dp/B004FM92Z8
As I sharted here, I fully confirmed the full sync connection by AES/EBU from OKTO DAC8PRO (Ch-1 and Ch-2) into Onkyo DAC-1000; when DAC-1000 is fed digital input through AES/EBU, the sync clock signal is given by upstream gears (DAC8PRO), and DAC-1000 does not use its own internal clock; in this way DAC8PRO and DAC-1000 are fully in sync. An ONKYO engineer also confirmed by email that "If DAC8PRO's AES/EBU digital out is fully compatible with the IEC90958 of AES3 Standard issued in 1985, then DAC-1000(S) would be automatically fully in sync with DAC8PRO, without using DAC-1000(S)'s internal clock."
The S/PDIF inputs on a Cambridge Audio receiver I had were specified as 96 kHz max. I connected a 192 kHz source anyway, just to see what happened. The receiver started smoking.At best it simply will refuse to connect at the higher rate. At worst it connects with lots of errors leading to dropouts and popping noise.
S/PDIF is strictly unidirectional. There is no way for the receiver to signal anything to the transmitter, so automatic rate negotiation is not possible. Some sources let you manually configure the maximum rate to output and will then resample anything exceeding that limit.IIRC there is no hand-shaking so no means of down-sampling and I don't think I have seen any component automatically do that (there may be some receivers now that, upon getting too many errors, try a lower rate).
Computer networks work with the so called OSI model or protocol stack. Ethernet corresponds to the Link layer. Every packet sent contains information about each layer, and each end device uses it in different ways. For instance, a router will typically only implement Link (ethernet) and Network (TCP/IP) layers. (there are routers that analyze application layers).and I thnk ethernet though am not familiar with that protocol
Very simple, this problem won't happen using the common network protocols.that an application receives an audio file with a higher bit rate than expected, I think there is no way for any layer in the protocol to detect this problem
Just for curiosity. The receivers keep sending this messages every t seconds or they respond when a possible sender asks for devices in the net?Very simple, this problem won't happen using the common network protocols.
UPnP is a popular one for streaming AV.
Indeed it is PnP (Plug and Play) because the devices discover each other over the network.
Just like in case of USB, they exchange their properties like "I can play 24/96 kHz PCM max", "I play FLAC", etc.
Hence the server knows the properties of the renderer and will down sample if needed. Likewise will convert if needed, etc.
Always liked toslink, one way it has an advantage of a coaxial connection is electrical isolation between the source and the DAC.Thank you for the quick replies. I think I’ll try the coax first, and if there is a problem I’ll try the toslink.
But to detect each other someone has to send the first message over the net. I was just curious to know if the end devices are telling they are there waiting for someone to connect to them, or when a streaming device gets connected to the net it sends a signal to let possible end devices to know about its presence and then they communicate their "properties" as a response to this request. Not very important, just curiosity.To the best of my knowledge, on detecting each other, they exchange their properties.
Don't know their polling rate if this is what you are asking for
