Cone Material
Goodman
Aside from the very exotics like belerium etc.. what is the consensus on mid-range cone material, paper, bextrene or Kevlar. I find lots of info on paper, bextrene and various other plastics but nothing on kevlar; Davis acoustics seem to be one of the few to manufacture kevlar speakers.
VintageFlanker
Paris
Davis Acoustics doesn't have a clue how to properly design speakers, no one should care about what material they use, since they do not know what yo make of it.
Paper is probably the most common. Yet, there is no consensus.
F
freemansteve
Guest
However well treated, paper is hygroscopic. Not a big deal in some climates, but less good in other places, long-term.
AudiOhm
London, Ontario, Canada
Thank goodness for paper as a cone material.
When I re-foam speakers I will also make a water 80% - glue 20% mixture and
use a brush to cover the cone with it to help stiffen it up.
Not to be used in any other application...;)
Ohms
alex-z
Bextrene and other plastic variants are generally inferior to treated paper, unless a complex weaving process is used in manufacturing. From a practical perspective, aluminium is usually the best choice, being relatively cheap with performance that can exceed paper. However, if you are forced to add damping layers, the additional mass negates that performance advantage.
DVDdoug
I've seen paper cones in the rear-deck of a car deteriorated from the sun. But I have home speakers with paper cones that are about 40 years old and still OK. I don't know if there is any kind of coating but they just look-like heavy-paper. The midranges have cloth surrounds and the woofers have rubber surround. (The tweeters are mylar).
I've seen lots of disintegrated foam surrounds. I don't know what they use for the foam but it's obviously not the same as the (butyl?) rubber used in my woofers.
nisse.P
Exciting materials exist https://www.composite-sound.com/
mightycicadalord
Ohms
I've thrown a coating of mod podge on some pa subs before, they looked more expensive after and had at least some protection from moisture. They're probably 10 years old and still going :)
ahofer
New York City
Harbeth posts a bunch of samples in this thread to justify their RADIAL drivers. Frustratingly, I haven't seen these assertions connected to measurements.
steve59
My VA beethovens have a cloth dome tweeter and it might be the most resolving tweeter i've heard without going to the $500 Be units used by revel in their ultima 2, Magico and some other expensive models.
sq225917
Spread tow carbon,various reinforced papers or the ceramic used in accutons.
Newman
One can find terrible and excellent examples of all the above materials, hence I conclude that design and implementation are so much more important than material that it can drop out of the buyer’s decision process.
I also conclude that the many discussions on ‘the sound of a cone’s material’ are misguided, and dominated by confirmation bias (provided we are talking about examples with good design and execution).
G
Goodman
The question implies that all these different material are well implemented; some manufactures like Kef have used bextrene plastic for decades, some base their whole advertising on new exotic cone material, it all leads to a sound signature that measurement will not confirm.
Newman
That’s just marketing. Believe it at your peril.
JRS
Albuquerque, NM USA
I use polypropylene midbass drivers. :eek:o_O:eek: Woofers are impregnated paper. Ribbon tweeters--aluminum.
Thought this was interesting:
Newman
Holmz
Australia
LOL, not!
The joke probably lost something in translation.
It is “Bullet Proof” in the sense that Kevlar is used for bullet proof vests, and the same Kevlar as “Aramid” in tyres.
Why one needs a bullet proof cone is questionable..
valerianf
Los Angeles
Long time ago Audax made several fiber glass midrange speakers and the end result was quite positive.
I am still owning one of them.
It is difficult to say which material is better than the other because the midrange crossover design has a very important
effect on the sound quality.
