Converting impulse .wav into parametric?
Couldn't find any info on this, is there a way to export a HeSuVi impulse as a parametric EQ? I want to apply it to wavelet but it doesn't have convolver support. Appreciate any responses.
NTK
US East
Have you tried importing the impulse response into REW, set the target to flat, and generate the PEQ's? You'll need to reverse the signs of the PEQ gains since the REW generated PEQ's are opposite to the FR of the impulse.
