DAC with MQA, balanced outputs and headphone amp
P
pinkish
No, there is balanced output in addition to the balanced input on the amp :cool:
Ohhh, so the balanced output on the headphone amp is for speakers?
Forget the signature stack and look at the Zen DAC which has a (pretty weak but maybe enough) headamp, rca for a future separate headamp and use the 4.4 to your speakers.
My Sony MDR-7506 phones have an impedance of only 63 Ohms. iFi DAC specs say:
4.4mm Pentaconn (BAL)
330mW@32 Ohm; 6.6V@600 Ohm;
16 Ohm - 600 Ohm Headphone
6.3mm S-BAL (SE)
230mW@32 Ohm; 3.3V@600 Ohm
Will that work for my headphones?
Jimbob54
6.3mm S-BAL (SE)
The amp has balanced out on the front for headphones and on the back for speakers /poweramp
The Zen dac headphone out might be enough for your phones. If it isn't, you can add a topping L30 /jds atom etc for 100 - 150 E and still be quids in
P
pinkish
Cheers, now I got it!
All the guys that wrote on this thread helped me understand stuff and I can make an informed decision now. I've been on many forums over time, but never felt better than here - great advice and no 'eyes rolling' because of my newbie questions.
Thank you all! :)
netizen
I apologize for interfering the topic but I am in the same lane.
Just need a DAC which can unfold MQA from Coaxial or Optical input and better than internal one of Bluesound Node 2i.
Kerrnel
I am trying to find a DAC to suit my needs. I was about to purchase the DacMagic 200M for my birthday until I saw it had A LOT of problems.
I want a DAC that has:
- MQA decoding
- balanced XLR outputs (for powered speakers - Adam T7Vs)
- headphone amp (for my Sony MDR-7506)
- 32bit/768kHz PCM, DSD, DXD
- USB (I will feed the audio from my computer)
- ground powered, not by battery
I've looked around for ages. The Schiits don't have MQA decoding, the 200M has issues, others are battery-powered and so on.
Maybe you guys can help me out, since I'm really a newbie. I'd very much appreciate it!
You write ”a LOT of problems”. What problems and where are they documented?
P
pinkish
I was all wrapped up in forum searching at the time. At this moment, I don't recall what exactly lead me to that statement, but there was something about it.
Anyway, in the meantime I got an iFi ZEN DAC v1 and I'm very statisfied with it :)
