DAC with XLR Output
geshwin
Hey there,
I am looking for a device that fits my system like so:
PC --> [?] --> Power Amp --> Speakers
Since the sole source is my computer (as I use EQs there) I am looking for a device that works as a USB Dac, has a nice and sturdy volume knob and an XLR output to the Amp. Must work with Linux. I noticed that many also include a headphone amp, but since I do not need it I would prefer a device without if possible. I compiled this short list of options and I would love to here more suggestions and opinions. In general I would prefer a second hand product if possible.
  • Hegel HD30 (as soon as I win the lottery, sure)
  • PS Audio Stellar Gain Cell (not cheap, a used one is around 1200€, not sure if I am actually willing to pay that much)
  • Cambridge Audio DAC Magic Plus (around 300€, cheapest solution. Some people say the knob is wack and not nice)
  • Parasound (so many options, not sure which would be best for me)
  • Topping (again, so many options...)
I would be thankful for some information on the last 3 brands, which give the best performance for my needs? And, which product to take?
pma
Prague
I have had this unit since December 2016, daily use, not a smallest problem. Also no problem with the knob. Yes, it is made from plastics.
Ken Rockwell's review
https://kenrockwell.com/audio/cambridge/dacmagic-plus.htm
and also by @amirm
https://www.audiosciencereview.com/...measurements-of-cambridge-dacmagic-plus.6887/
The sound is very good, detailed, natural, not over-bright. I appreciate 2 fiber optic inputs.
Reactions: PSO
M00ndancer
Sweden
Some examples of the best "Highest measured DAC with XLR and volume knob" (not counting Linux support, you have to read up on that)
Sorted by price:
Reactions: PSO
earlevel
Very happy with my Topping DX7 Pro. If I absolutely didn't want the headphone amp, I'd be tempted by the D90, but I'd miss having the volume knob (and you did request a volume knob). Heck, if I had to rebuy tomorrow but without wanting a headphone amp, I'd probably still buy the same. I'm using the XLRs to drive powered monitors (iLoud MTM). Right now I only need the USB in, and it works great with my Mac, sleeping and waking just right. It's nice to have the AES and optical, as I do have gear that could use it—perfect i/o setup in general for me.
Reactions: PSO
Bob-23
Berlin, Germany
Hey there,
A dual rca to xlr adapter might widen the range of your choice:
https://www.amazon.com/Tisino-Split...ca+to+xlr+adapter+cable&qid=1608063008&sr=8-3
I use an even 'cheaper' Behringer UMC204HD, as a dac completely sufficient, (apparently) robust build (note: output voltage is 1,1 V). You may find it from time to time on amazon marketplace at a reduced price. Includes an adc and an headamp, both not as good as the dac. (Don't be too impressed by the better measurements of other dacs - if I may exaggerate a bit: they all sound the same). Build quality, longevity may differ.
Amir tested it twice:
https://www.audiosciencereview.com/...04hd-dac-and-headphone-amplifier-review.2013/
https://www.audiosciencereview.com/...ringer-umc204-hd-audio-interface-review.9856/
Note: "I seemed to recall the output voltage was lower when I first tested it. So I dialed down the input by 3 dB and performance hugely improved"
Reactions: PSO
M00ndancer
Sweden
waynel
Hey there,
How about a Motu M2 or M4? (if you don't need a remote)
EdW
Cambridge, UK
Check out @amirm review here before spending your money here
https://www.audiosciencereview.com/...s-of-the-ps-audio-stellar-gain-cell-dac.9273/
rather less than stellar performance :)
A requirement for a rotary volume control does restrict your choices. For example if you were prepared to spend the same money as the secondhand PS audio DAC you could consider the Okto Research DAC
https://www.audiosciencereview.com/forum/index.php?threads/okto-dac8-stereo-dac-review.14705/
which is one of the finest DACs on the market at any price - but no rotary volume control :(
DACs have advanced so much in the last year or two that an older DAC design underperforms and is overpriced versus a newer offering. For this reason secondhand DACs may not be a very competitive
waynel
M00ndancer
Sweden
f1shb0n3
RME ADI-2 DAC is a great option - it has a remote, good headphone amp and can even do 5 band parametric EQ for your speakers and separately for headphones plus a bunch of other useful and unique features like crossfeed, loudness, etc.
If you plan to add a subwoofer to your setup you should consider MiniDSP SHD as a DAC, EQ and subwoofer crossover.
waynel
Reactions: PSO
M00ndancer
Sweden
No, but pretty good for ~$200, did you see some of the DACs the OP was considering?
Your totally right, but it's not in the top quarter, and my examples was. I'm lusting after the M2 or perhaps M4 to replace a lot of cables and the current mixer in my signal chain, lowering the noise floor. The Behringer Xenix QX1202USB Mixer is cheap and functional, but not close to silent.
My current setup
For music listening , games and general usage :
Windows PC -> USB -> Swissonic HAD-1 -> RCA -> Behringer Xenix QX1202USB Mixer -> Fluid Audio F5 (XLR) & H&K TS-7 Sub (RCA)
For "making" music:
Windows PC (DAW) USB -> Yamaha MODX6 -> 1/4" jack -> Behringer HD400 -> balanced 1/4" jack -> Behringer Xenix QX1202USB Mixer -> Fluid Audio F5 (XLR) & H&K TS-7 Sub (RCA)
With the MOTU M2/M4:
Windows PC -> USB -> MOTU M2 -> Balanced 1/4" jack -> Fluid Audio F5 (XLR) & H&K TS-7 Sub
For making music:
Windows PC (DAW) -> USB MIDI, Audio and data -> Yamaha MODX6 -> 1/4" jack -> Behringer HD400 -> balanced 1/4" jack -> MOTU M2
Windows PC (DAW) -> USB -> MOTU M2 -> Balanced 1/4" jack -> Fluid Audio F5 (XLR) & H&K TS-7 Sub (RCA)
TchErNoB
what about the gustard X16 ?
it s balanced not so high in price and with remarquable mesures
