Denon AVR-X3700H AVR Review
jgiannakas
But, you don’t get the internal amps to turn off unless you use all external amps. I believe the 8500 can do the mix match of internal amps off per channel, but none of the lower model Denon do this.
If your external amp maxes it’s output with 1.4 volts input you don’t need to disconnect the internal amps - there is no benefit sinead wise. If you’re willing to accept a sinead reduction you can drive as stated above even higher inputs but with some degradation in quality compared to if having the amp in preamp mode or 11 channel mode.
Acerun
San Francisco
On a scale of 1 to 10, how concerned are we that the current 3700h available isn't the same unit as the one Amir reviewed due to the DAC swap and could potentially have inferior performance?
Webninja
Los Angeles
Unless you are getting a refurbished or used x3700h, all the new ones now have the ESS DAC.
So not the same DAC as the 3700 tested here, but Amir did test the 8805 and concluded
“Anyway, good news is that switch to ESS DAC from AKM has not resulted in any harm. Overall performance remains quite similar.”
My take is that there isn’t any better AVR for the money than the x3700h, and I wish I got the AKM DAC, but that is not an option and I doubt there is an audible difference between the old and new DACs.
peng
The 3700 may get the ESS one but wont likey be the same one in the 8805A, only the 8500 will get that one. But that's just a guess, for now.
peng
Masza
Acerun
San Francisco
I'm considering getting a two-channel Buckeye amp for pure stereo use with the 3700h.
1. Any problem with using that amp and my 3700 for stereo?
2. Can I use it for two channel stereo and still use my subs?
Acerun
San Francisco
That is only true if you have an external amp that needs more that ~1.4 volts to reach full power. Anything below that and the dacs SINAD is actually pretty good.
So putting the amp in preamp mode eliminates the sensitivity Issue and maintains high sinad?
peng
Sensitivity may or may not be an issue for you because it depends on your power amp's output specs at your targeted SINAD, and most importantly your estimated power requirements.
If you can estimate your power requirement (you can use an online calculator) then you could get a more definitive answer to your question.
You would need to know your speaker's nominal impedance and sensitivity specification.
Another potential effects on performance in terms of SINAD using the 3700 to the buckeye amp is that you would have to use a RCA to XLR interconnect and you should make sure the interconnect cable is wired according to hypex's recommendations.
As far as I know, March Audio and Benchmark both sell a very good one. To be sure you can ask March Audio and Benchmark to confirm their wiring method or better still, ask for the wiring diagrams.
Acerun
San Francisco
Thank you. Do you happen to know if the subs will work with the fronts in preamp mode? Will Audyssey EQ still be engaged if set to ON?
Mrgoogle
This is a review and detailed measurements of Denon AVR-X3700H 9.2 channel 8K Home Theater AV Receiver (AVR). It is kindly loaned to me by a local member and costs US $1,199.
Visually, if you have seen one AVR, you have seen the look of the AVR-X3700H:
The input selector is plastic and while rotating it feels fine, the plastic feel is a bit jarring because you expect it to be metal. AVRs though are universally used with remote controls so this is just a minor nit.
The back panel has the typical connectors including the single new "8K" capable HDMI Input:
The 3700H is lighter than its higher end siblings which I personally appreciated as I lugged it around.
In use, the unit was quite robust, never shutting down no matter how much I pushed its amplification in my standard tests. Other AVRs can be very sensitive, constantly shutting down when pushed, often requiring a power cycle. Not here.
The 3700H does run warm and I will show the thermal imaging of it later.
There is a lot of anticipation for this review as I gave its last year mode, the AVR-X3600H my best rating of any AVR tested. Alas, I reviewed that late in its design cycle so availability is very poor. Hope is that this replacement unit doesn't regress in measured performance while adding features. So let's get into that.
Note: Denon engineering was kind enough to review these measurements and confirm that they match their expectations.
AVR DAC Performance
As usual, when we have pre-amplifier output functionality on an AVR, we feed the unit digital 1 kHz perfect sine wave and see what it outputs in analog domain (amplifiers shut off):
Ah, that is a sign of relief. SINAD which is the sum of noise and distortion is in the same ballpark of AVR-X3600H:
One to two dB difference is to be expected so no cause for concern. I also tested Coax input (not shown) and it had the same performance.
My standardized tests use 2 volts output but since you can't turn off the amplifiers beyond 2 or all channels, let's see what the performance is like for other output levels before the amplifiers clip and drag down the performance of the DAC subsystem:
As you see, peak performance with the amplifiers off is around 1.1 volts with SINAD of 101 dB which is excellent for an AVR. With the amps on, you are OK up to 1.4 volt output before it nose dives. So when selecting an external amplifier for channels beyond fronts, make sure it can output its maximum power at or below 1.4 volts (usually specified as "sensitivity").
Signal to noise ratio is about the same as 3600H as well:
32-tone test signal which simulates "music" shows more intermodulation distortion than the 3600H:
Here is the 3600H for reference:
The 3700H though evens the match by producing near perfect linearity (accuracy) score:
Back to intermodulation distortion, here is how it varies with level:
Jitter performance is the same as 3600H in both good and bad ways:
Coax/Toslink inputs generate a ton of jitter and spurious sidebands (tones). Levels are very low though so more of a visual distraction than what is audible. HDMI achieves a lower noise floor which indicates the other inputs suffer from random/broadband jitter. However, the HDMI jitter profile is different (blue) showing that better care could be put in there to isolate the DAC from what is around it.
The filter performance is decent:
The attenuation here is better than what we get in the higher end AVR-X6700H which is an interesting "reversal of fortunes:" (label on graph is wrong -- should say AVR-X6700H)
Poor attenuation usually makes our broadband distortion+noise versus frequency worse. So good thing the filtering is better in 3700H:
HEOS Streaming Performance
Here is a quick test which shows streaming performance to be similar to HDMI/Coax inputs:
AVR Amplifier Measurements
I have been testing Denon AVR amplifiers using CD input which I have found to not be digitized allowing us to see the true performance the amplifier rather than any processing blocks. Question has been raised as to what happens when you turn on signal processing such as bass management. Here is the answer:
The answer is naturally, the AVR will digitize such analog signals the moment you do that. As it should. Fortunately the Pure Direct button overrides that as show in red graph. Digitization is at high sample rate of 96 kHz which is nice. Note that level changes a bit so be careful if you are doing AB tests.
For the rest of these tests I will be using CD input in pure-direct with speakers set to large.
Here is our usual dashboard with 1 kHz tone again:
Denon once again shows that its amplifiers are above average even though many channels are stuffed in a "mass market" product:
And within all AVRs tested:
I wish the dynamic range was 6 dB better to clear CD at 16 bits (which the 3600H achieved):
Crosstalk is a bit disappointing but Ok from audibility point of view:
Power output versus distortion and noise which is one of the most important metrics into 4 ohm shows respectable results:
Allowing distortion to grown to 1%, we get even more power, continuous or peak:
That's good bit of headroom which is nice to have in any amplifier since peaks in music can be momentary.
Switching to 8 ohm load we get to compare our measurements against the company's spec: (label is a typo: should say 3700H)
Testing frequency sensitivity with full power sweep we get:
This is a bit less tidy than 3600H but still far better than many other amps, specially the switching/Class D ones.
Note that as is typical, power output drops at 20 Hz (orange) which is where you need it most.
AVR Power Scaling with Channels
There is a shared power supply in all of these AVRs so as you turn on more channels, power you get from each channel drops:
AVR Heat & Thermal Analysis
Denon & Marantz AVRs tend to run warm especially if used without the ECO mode. The 3700H doesn't get as warm as its larger brothers which is good:
Can't figure out why the hot channels are in the middle even though the speaker terminals are all the way to the right. So perhaps that is how they are wired.
What a sigh of relief that the Denon AVR-X3700H performns on par with the later year mode, 3600H. The other "2020 year" Denon AVRs we have tested have had worse performance, leaving the 3600H as the best performing AVR until now. So buy the 3700H with peace of mind knowing that it performs quite well (for an AVR). Of course be mindful of what other features the units above it have which you may want, top of which is more power.
I am happy to add Denon AVR-X3700H to my recommended list.
Get this: money is so tight that I not only have to mow my own lawn, but had to fix the darn riding mower myself!!! Sweating in hot sun, fixed the rusty connections on the solenoid to get it to start reliably. Please rescue me from this misery so I can find other people do such work by donate what you can using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Amir , just wonder why you didn't measure DC offset at output with maximum volume with grounded input ?! we don't know how much DC is at output ! do we ?
peng
The subwoofer outputs and Audyssey EQ both work independently of preamp mode.
Ale Dors
AVR DAC Performance
I created an account in this forum to respectfully leave my personal opinion because it may, or not, help others:
- I don’t understood all the posted analyses and comments here but they surely sounded really impressive;
- I was inclined to buy a Marantz avr before I did read all these audio/processing technical reviews but I ended buying a Denon X3700H afterwards;
- I had several receivers in my life but I never experienced something so vanilla, so transparent, so nothing;
- I won’t even try to express my frustration in words, impossible. I will just state that I put all my money in something that I wouldn’t accept for free;
- Finally, I decided to proceed with my original plan: I bought a Marantz SR7015 and all the distortion mentioned in this forum sounds like heaven to “my” ears.
Bottom line: always judge what is good or bad for “you” and there is no technical test in the world capable to replace an in loco demo.
Cheers,
Alex
AVR DAC Performance
FrankF
North of New Haven
- I had several receivers in my life but I never experienced something so vanilla, so transparent, so nothing;No
Cheers,
Alex
Now you need a 9 channel SET tube amp to go with it.:)
Ale Dors
Vincentponcet
Does anyone have the service manual of this ?
I would like to see if this would be easy to add digital output on this unit.
bigguyca
With the most simple of Google searches you will find the manual
Assuming we are discussing the Denon X3700H, please do me a favor and run a simple Google search and find a source/link for the service manual for the X3700H.
xovaan
Hey everyone,
I'm finally putting together the "home theater" part of a home theater and receivers are new territory for me and tad overwhelming. o_O Wirecutter recommended the x3700h and I want to make sure it's the right buy for my needs :)
Current setup:
- Nvidia Shield Pro + JDS Atom DAC -> SMSL DA-9 amplifier -> MAOP 11 towers (35 watt speakers)
- Picture fed to a projector (BenQ HT2050A, 1080p@60hz)
I will be building another MAOP 11 center channel and possibly getting a subwoofer or two to go 3.1/2, with the eventual goal of 5.1/2 (I think 7 will be overkill).
Things that interest me:
- Pass-through for stereo listening, unless anyone knows if the 3700 outperforms my current Atom DAC + SMSL DA-9 setup?
- Using the Nvidia Shield Pro as my media hub for Plex, Spotify, etc.
- I also use Nvidia streaming from my PC to my projector. My friends may bring over a console as well
Would the 3700 be overkill?
Thanks in advance!
