HarmonicTHD
- Joined
- Mar 18, 2022
- Messages
- 3,326
- Likes
- 4,836
Ah yes also good idea.Sure, most likely, but for me the solution was using the trigger outputs. The 3800 have one and could potentially be put to good use.
This is not common with Denon and seems to happen only with certain sub brands. Seen complaints around SVS.In this same thread, another user, in this post, wrote that he returned his 3800 because, among other things, his subwoofers weren't turning on automatically because of the signal being too low to engage the function
I have two Klipsch SPL-100, with my Onkyo they turn onThis is not common with Denon and seems to happen only with certain sub brands. Seen complaints around SVS.
Any reason to use the RCA to XLR cable to not get speaker hum or a ground loop? These cables are not very expensive if they may help. I am going to run the front 3 LCR in pre amp mode and re assign the 2 channels to Hight 2
Well I have not hooked it up yet but I will be using a receiver with my 3 channel ATI Amp I will have RCA on the AVR and RCA and XLR on the amp. I do not have hum as it is not running yet. But I want to use the best set up from the beginning and I thought an RCA to XLR migh be the better way. It is only a question and was hoping some one has don this in the past. The AVR will be close to the amp I am hoping 1.5' cables or max 2" will be needed to connect. So RCA may be fine but again lust looking to start of with the best setup I can.I know it may sound obvious, but have you tried solving the issue that causes the hum? Most likely it's a ground loop you can easily overcome by wiring together the two devices' chassis.
I just ran across this on Youtube.There is good chance that it would at least reduce the hum, if the RCA to XLR cables are via like it was suggested by Hypex. The Monoprice premier cables should work good.
Benchmark RCA to XLRM Adapter Cable for Analog Audio - pin 3 to RCA shield
BENCHMARK STUDIO STAGE™ RCA TO XLRM ADAPTER CABLE CABLES ARE SOLD INDIVIDUALLY. Price is for one cable, order 2 for a stereo pair. Hand assembled in the USA with true silver solder Applications This special adapter cable connects unbalanced analog RCA outputs to balanced analog XLR inputs. Use...benchmarkmedia.com
You can also try connecting the chassis of the two devices together as suggested, that may or may not work, but in my experience, it rarely worked.
Not sure if it is accurate.
Thoughts?
I dunno how this RCA-XLR "hybrid" cable can work: the balanced interconnection is based on the fact that the signal is "mirrored" (counter-phased) at the source and the two copies run on different wires (the reason why XLR has 3 pins, while RCA just 2), so that all the noise that gets picked up gets canceled because of its random nature.Well I have not hooked it up yet but I will be using a receiver with my 3 channel ATI Amp I will have RCA on the AVR and RCA and XLR on the amp. I do not have hum as it is not running yet. But I want to use the best set up from the beginning and I thought an RCA to XLR migh be the better way. It is only a question and was hoping some one has don this in the past. The AVR will be close to the amp I am hoping 1.5' cables or max 2" will be needed to connect. So RCA may be fine but again lust looking to start of with the best setup I can.
Thanks
Btw a real balanced system has to be balanced from inside the source device to the end of the amplification chain: that means that all circuitry must be doubled, with a huge hit on production cost. So most devices that have XLR plugs have just a conversion circuit and are not internally balanced, thus making the balanced connection worse than RCA, unless you have to use balanced because you have the two devices very far apart.
I do need the male RCA to go into the AVR. This guy is reading from the Emotiva site. Will a configuration like you linked on page 17 from Hypex stress the components? Emotiva says it is not good. This is confusing. One company says it is correct and one says it is wrong.Some Youtubers are very knowledgeable in the topic they talk about but some are not. In this case, he's talking about a cable for connecting balanced output to unbalanced input. If that's what you want to do, then this cable may work for you, but that's if the female RCA cable is what you need, otherwise you can get one that has male RCA.
The Monoprice I linked is for connecting unbalanced output, such the pre out of an AVR, to the balanced input of a power amp, and I thought that's what you want to do.
Benchmark sells both, one for each application, again the one I link is for RCA out to XLR in, the one linked below is for XLR out to RCA in, the difference is, in this case, pin 3 is left floating:
Benchmark XLRF to RCA Adapter Cable for Analog Audio - pin 3 floating
Benchmark Studio&Stage™ Analog XLR Cables CABLES ARE SOLD INDIVIDUALLY Price is for one cable, order 2 for a stereo pair. Hand assembled in the USA with true silver solder Benchmark Studio&Stage™ Analog XLR Cables combine the best cable, connectors, and construction techniques in order to offer...benchmarkmedia.com
So, pick your choice accordingly.
For XLR out to RCA in, there is a whole ASR thread:
XLR output to RCA input done properly?
If I want to connect my DAC's XLR output to a preamp or integrated amp's RCA input, what are my options? This Emotiva adapter cable seems to do it "properly" https://emotiva.com/products/balanced-xlr-female-to-unbalanced-rca-female-adapter-interconnect but it'd be nice to have a cable wired...www.audiosciencereview.com
For RCA out to XLR in:
Good quality RCA > XLR cables
I'm looking for suggestions for good quality RCA to XLR cables. I know these will by definition be unbalanced, but looking for ones that are wired correctly and use high quality connectors, such as from Neutrik. No snake oil :)www.audiosciencereview.com
There are likely many more such threads to read if you are interested.
Thanks
I have both RCA and XLR input on my amp. The AVR will have RCA out only. The will be next to each other on a shelf so the cable should 1.5' to 2' so not too long. But I am asking before I buy cables if it would be better to get the RCA to XLR or just RCA to RCA. I just want to make the best decision upfront.Then just get a RCA male to XLR male cable, like the one of those I linked earlier, in post#1749. All 3 pictures show male to male! Do want the XLR end to plug into your power amp's XLR input?
This is a quote off the Emotiva site:Did Emotiva really say that?
Can you link the source please? Or you get confused by the two different cables mentioned, for two different applications.
To be clear:
1)The cable that Youtuber talked about, is for interconnecting the XLR output from something such as an AV preamp/processor output, to the RCA input of something such as a power amp.
2)The 3 cables I linked are for interconnecting the RCA output from something such as an AVR preamp output, to the XLR input of something such as a power amp.
The Proper Way To Connect a Balanced Output To an Unbalanced Input
When connecting a balanced output to an unbalanced input on modern audio gear, the proper way to do so is to connect the non-inverted output on the balanced output to the unbalanced input, and leave the inverted output unconnected. Many adapter cables, designed primarily for use with microphones, short the unused output pin to ground. While most equipment, including ours, will tolerate this without damage, it is not recommended, and may unnecessarily stress the output circuitry on your processor or preamp. This adapter was specifically designed to work optimally on modern balanced audio gear - and leaves the unused output line unconnected.
I have a Denon 4700 AVR and a pair of SVS SB2000 subs and have no problems with auto turn-on. Let's not spread unsubstantiated rumors.This is not common with Denon and seems to happen only with certain sub brands. Seen complaints around SVS.
I mean what do you expect.Sorry if this was already posted. Interesting new vid posted yesterday on the new x2800/3800/4800:
I like how the new 3800/4800, for unified Atmos/Auro3D setups, will prioritize Atmos sound quality over Auro3D (by allowing Auro3D to utilize the top instead of height speakers, whereas the previous generation did the opposite).
I also like how they still insist Denon always improves performance with each new generation, even with the new regressions and then indicating performance is still good enough .
Now someone please get a 4800 to Amir to see if Japanese production addresses the performance regressions.....
Agree. My KF92s switch on without a hitch (X3700).I have a Denon 4700 AVR and a pair of SVS SB2000 subs and have no problems with auto turn-on. Let's not spread unsubstantiated rumors.
