I did review the measurements, as you can see I even attached the summarizing tables Gene presented!
Obviously you are right about the Monolith's 98.4 dB, in that sense it would out match the 4700, preamp mode or not. Not to confuse Gabriel though, I would emphasize that the 4700's SNR is adequate probably for most users. Put it that way, talk about in real life, my much older 4400 is quieter than my AV8801 such that I had to turn the volume well pass 0 to hear any hiss from a couple feet and it is silent under all conditions from 11 feet.
If we are to use the graphs for comparison, as I mentioned before too, it is much preferred, so no disagreement there. But then you have to compare graphs to graphs. Of course the preamp mode graph shows better SINAD at above 1.4 V, but up to 1.6 V, the non preamp mode graph is still a good match to the Monolth amp, or at least an adequate match, on paper and in terms of SINAD anyway.
I highlighted the non preamp mode performance not because I don't prefer preamp mode but because GabrielPhoto specifically asked:
"But 80db is way lower than in preamp mode. Wouldn't that be easy to detect in real life?" I know you said you noticed a difference in your application but you also said, some may not. I did repeat myself making the point that it would depend on one's speaker sensitivity, spl requirement, and distance, among others. Another point is, as repeated many times on ASR and other forums, people who did subjective measurements, while useful and appreciated, their perceived results (difference, better, worse...) are almost always anecdotal unless the test protocols are fully disclosed such as whether they were done sighted, blind, double blind. People may think the difference heard is so obvious, even night and day to them, yet there have been studies that showed that such obvious difference would disappear or reversed in blind tests. Not all such reported tests are reliable I suppose, but I would some of them were, such as Harman's. So, it is in fact a tough question to answer in terms of "....to detect in real life...". My suggestion to Gabriel is just based on the available data. To know the truth (if there is such a thing
) is not going to be easy, or even possible, for reasons stated. One can tell him it would be easy to detect because amper42 could (just a fictitious example..), others, say me (also just a fictitious example) would say, no I doubt you can, because I can't..
I would add in my recommendations to
@GabrielPhoto so far, that he can always try both modes, and return the extra power amp channels (needed to test preamp mode) if he cannot detect a difference. Though the fact remain, are the perceived difference real? To me, that would remain an unknown unless he could actual do such apple to apple AB compare the modes in DBT at home.
By the way, on a side note, you, and GabrielPhoto can also compare the following two graphs, that would be the 4700's combined SINAD vs the Monolith's power amp SINAD vs output level:
Don't you think even when comparing the Denon (again, complete with preamp+power amp) with the Monolith power amp only, the results are very comparable?
If you use the 4 ohm graphs to compare, the Denon's SINAD, at -86 dB versus the Monolith's 0.007% (approx., by eyeballing only), that is about -83 dB, the Denon (combo effects), actually looked better on paper. Keep in mind we are comparing results from two different benches, both using the Audio Precision instrument with presumably comparable accuracies, so a few dB difference doesn't mean one is better, but it is reasonable to say the two are likely comparable for this one particular metric.
