Fair question, not sure what the answer should be, but I'll try 30 to 60% may be?
how about -40dB fair ?
I don't want to disclose what I know but there is a distinct difference between 3700 and 4700. When I get a 3700, I can verify if that solves a few of the issues.
glad you askedWoah hang on there, chief. Where are you seeing -40dB “distortion” measured for the x4700?
I bet the best case is that it would take 2 months for Denon to fix and for Amir to confirm something is improved. That's only if a firmware fix is possible. So you may want to return during your return window, especially if ita free return. There is always something new for audiophiles to lust after. Or you might buy it 6 months from now at a lower price.Without revealing any details, could that "distinct difference" be addressed by firmware update, or only through hardware change?
The reason I ask is that I have a new X4700H unopened still in the shipping carton. Out of protest, I'm willing to return it. I can wait if Denon can't address this, instead of contributing to their sales numbers for the X4700H.
Agreed to both of you because a) preload is right but only if Amir or Denon can explain why the 32 tone test results and the linearity (to lesser extent) were so bad, and b) if a) is explained and would not have been bad, but we still focus on the "engineering excellence part..".
Otherwise, i.e. if a) is in fact not so bad as it appeared for valid reasons, then while I fully agree we as hobbyist are doing the right thing complaining about the poor results of a higher/more expensive model, we should make some effort in the way we complain, that it may (and evidently it has) lead less informed/technically less knowledgeable potential buyers and owners (worst in that case) to think that this is in fact a product to be avoided, and may even end up buying a competing product that could have been shown worse, if measured by ASR.
So to summarize, I think it is good that we complain like we have been to Denon, but do it in a more balanced way. For example, we can say 75 dB SINAD using HDMI input is much worse than the lower model and totally unacceptable, but it is as good as some separate processor only device such as the AV7705 (when measured at 4 V XLR), to put things in perspective, etc. etc..
glad you asked
First post. On the first page. Multitone distortion at -40dB. Actually, I might be wrong and it's -39dB. Sorry for my aging eyes.
And even using some of the "better" numbers like the 75dB SINAD, your car analogy is still off by a level of magnitude. It'll need about 2minutes in that case. Sorry, your "latest Camry" is still thoroughly broken.
If you don't mind me asking, why did you think people were calling the x4700 catastrophe and trash and so on?!
I know. But if it's not possible to fix without a hardware update, that pretty much makes the decision for me.I bet the best case is that it would take 2 months for Denon to fix and for Amir to confirm something is improved. That's only if a firmware fix is possible. So you may want to return during your return window, especially if ita free return. There is always something new for audiophiles to lust after. Or you might buy it 6 months from now at a lower price.
If I were to make a wild guess, my answer would be yes. But please don't set your expectations one way or the other. It is too early.Without revealing any details, could that "distinct difference" be addressed by firmware update, or only through hardware change?
I did not ask that question but I assume the 6700 is the same as 4700 in this regard.Any gut feel on where this possibly distinct difference might fall in relation to the x6700h design?
First poster.
Will anyone be sending Amirm a 6700H to test against the 4700H?
I'd be interested to know the difference. The 6700H is assembled in Japan I believe?
That's what I suspected you were looking at. I don't think you're interpreting the IMD chart correctly. Look at the x-axis - it's "generator level." The IMD is only -40dB when the digital input level is -47dB. To use your example of recorded explosions in a movie, where the digital input level would be around 0dB, the IMD is actually -82dB. Also, Amir's annotations indicates noise is an issue, so it's also not clear whether -40dB at very low input levels is a function of IMD or if it's a function of noise (which would be much more benign). This is how I interpret the chart, but perhaps I'm mistaken.
I have just joined the site after purchasing my new Denon X4700 and I made an “unboxing video with a nice twist. My first you tube video I have ever made so don’t be too hard on me. I hope the audio quality will be firmware patched cause I’m just going to stick with the Denon as I already paid for it so her it is everyone.
Thanks for posting these. I see TI PCM5100A as the DAC chip.
I don't know if they are used for all the channels or just the non-main ones. They are pretty low spec DACs from TI:
Change the sign from negative to positive in the last column and you get SINAD. They opted for the lowest grade of this DAC chip getting it only 90 dB SINAD. Here is the actual graph akin to THD+N vs level that I show:
So it can get a bit better than 90 dB which is what I showed.
This very much verifies my measurements to be correct as I got 92 dB with Toslink input.
With CD having a dynamic range of 96 dB, clearly even in ideal case this AVR can't resolve CD let alone higher resolution.
The DAC chip is stereo so gives you two channels and it costs just $1 in thousand piece quantity. In other words, 50 cents per channel was invested to produce sound out of this AVR.
The above would be fine if we didn't have flowery words about how great its audio subsystem is. But we do have such words:
Earlier we talked about reference levels of 105 dB, etc. You can't get to those numbers with 16 bits which caps out at 96 dB.
We need an honest, 18 bits at least to sell products like this with a straight face. 15 bits and lower just doesn't do it.
Now, if we had a $300 AVR, that would be fine. But when charging over $1000 let's deliver the bits to people please.
Virtually all owners will use HDMI with the 4700H and something is amiss.
Until this is found the be an unusual case, not indicative of normal use, then no criticism can be considered unfair, IMO of course.
- Rich
I absolutely agree with you, the 32 tones test results is prohibitively bad, but it helps that at least you included a condition, not a blanket condemnation that would otherwise seem premature, or at least jumping to conclusion a little too quickly. My comments about fairness was not directed to comments you made, but only to those who I got the feeling (just a feeling so I could be totally wrong) that they didn't base their comments on the 32 tones test, might not even have paid attention to it.
Nobody is idiot...
I think that could be a myth, depending what compares to what. For example, I have owned the AVR-3805, 4308, 1912, 1710, X3500H and now the X4400H, also had the Marantz AV7005, AV8801. So for me "all those in the past" would include 6 of the models I mentioned and the "present" is the X4400H. In that case, I would say my "present" AVR perform not only as good, but actually better than those in the past based on available bench test measurements done by AH, S&V, HTHF, HCC, AVtech and of course ASR. That is, not based on poor ears/brains, but specs and measurements.
Again, not trying to contradict your point at all, just saying it depends..
So, this also means that this AVR cannot fully resolve hi-res audio streaming such as TOTAL or Amazon Music hi-res?
