Denon Replaces AKM AK4458 DAC IC in X4700H and X6700H
alik1006
Jersey City
Holy balls Denon pumped up the prices on all models of AVR's another 100 bucks. A Denon x4700h originally had a MSRP of $1699 now has one of $2099. Good news for resale value for those who bought models early before price hikes and intend to resale later on!
It seems they increased prices by $100 for all models. The reason is probably that they believe people don't have good alternative anyway so the demand is strong and supply is short/disrupted. Which is not an unreasonable assumption. Even if you look at this forum, Denon (and some Marantz) are the only recommended AVP/AVR by @amirm (probably misleading since tested models had different DAC) in this price range.
K man
Sweden
Do we have any projections on when D&M might return to the more high quality AKM DACs again?
dlaloum
Apparently AKM has started up production at their new facility - this will presumably take some time to work its way from AKM through the logistics chain toe D&M and then to retail.
I would bet on 6 months
best case estimation - at least 1 month from AKM to D&M manufacturer, 1 Month from D&M factory to Distributors at least a further 2 weeks for distribution to retail - so an absolute minimum of 2.5 months lag, without accounting for manufacturing time.... prioritisation of the various production lines, competition between customers for the AKM chips etc....
peng
I think it is easy for D+M to switch back because I am sure they have inventory and there is no need to re-engineer anything. They stopped using the AKM chips probably because they don't want to use up the inventory that they have to keep above a minimum number but as soon as they know AKM has resumed production then they can start planning on switching back. I do agree it will have some lead time, a few months may be enough.
alik1006
Jersey City
+ extra time for communication and collection of evidence to confirm that it is truly AKM
+ extra time to sell inventory of inferior DAC
+ extra time to "trickle down" from top level overpriced models
I do not think we should expect anything earlier than the end of 2022 before it can even be re-tested.
But of course, nobody knows and it is just a speculation. FWIW we can see X8500HA-PLUS next week. :)
K man
Sweden
I doubt x700 series will see AKM DACs anymore. I mean those models which already have probably re-engineered boards due to the previous DAC change. But hopefully x800 will get those AKM DACs.
That does seem like the most reasonable to me. Normally Denon release their new series around or after summer, right? That's about half a year from now. Why should they then go through the business and political hassle of another change, which they need to announce, motivate and explain.
From a business perspective it makes most sense to just keep things the way they are until next series.
SoundsGood64
Some in this thread will be interested in recent posts in this thread: Denon DRA-800H Review (Stereo Receiver).
The original DRA-800H had AKM4458 for the Main Zone in dual differential mode, as well as two additional DAC ICs, "Network (Z2) PCM5100A" and "Downmix PCM5100A". Denon has a revision now in which the AK4458 has been replaced with a PCM1690, documented in the above thread by photo and with measurements.
ianh
Ironic that I specifically looked for a post May 21 copy of a x3700h and was happy to find one on Friday, now I wonder if it maybe a mistake. Has anyone actually listened back to back to both the original and new versions who could comment on any perceived differences?
peng
It seems that we now know a lot about this receiver thanks to you and @User_22 , but in my opinion it only reinforced my original thought that whoever designed/market this product missed the opportunity. They put in a good DAC (originally) and buffer OPA and implemented it with differential connections yet they did not include the pre outs. That wouldn't be bad if the amp section is good, but it is not, according to the measurements it is about as good as the old entry level Denon AVR-X2200.
The Marantz version is much better because one can at least use it as a preamp/DAC.
peng
The problem is you even if many people would respond to your question, they would most likely offer their subjective opinions only. I do recall one member has in fact listened to both and if I remember right he didn't really pick a clear winner as such. The chance for anyone who have listened to both under a reasonably well controlled apple to apple comparison is about zero.
If you can confirm your unit has the AK4458, then you know it will have better performance (based on specs and measurements) than the one that supposedly has the PCM5102A. In that case I can't see how it could be a mistake, I mean relative to getting one with the no so good DAC.
Guenselmann
A few weeks later Denon Germany support confirmed to me via E-mail what we already knew, which is that AVC-X3700H with serial number:
smaller than xxxxxxx70000 has AK4458,
larger than xxxxxxx70000 has PCM5102A.
ianh
Turns
I found a post on this forum where someone had both versions and ironically preferred the new one! The unit I now have which was supposed to be the new one is actually confirmed by Denon to be the old one. Not sure if that’s good or bad! Will probably devalue it a bit unless the new ones really turn out to be much worse.
Masza
Maybe they changed some other components as well?
amper42
AK4458 is hard to beat. Sound United didn't change the chipset willingly. It was required as a result of the fire. I would not expect the PCM5102A to add value to the receiver. That would be a false narrative. If Sound United thought the new units were better they would have advertised the changes instead of systematically keeping the details under wraps.
peng
Turns
Congrats! Keep yours unless someone offers you more than what you paid. The AK4458's SINAD is 15 dB better than the PCM5102A. The difference would likely be not audible to most users but all else being equal I would always prefer the one with better specs and measurements regardless.
ianh
The 5th digit of the serial number on my X3700H is a 1 (<7). Does anyone know if there is a way to find out the manufacture date for these units? For example I have seen elsewhere that the first digits may indicate this MMYY, in my case it is DBCG1220 which may suggest Dec/2020.
ianh
I asked Denon support this question and they said there is no way to find out when a unit was made from the serial number. They confirmed the DAC change and HDMI fix happened coincidentally in May 21. I will stop investigating this now, the unit I have sounds ok for me. I also suspect the one with the TI DACs would have been fine. I will get one of the HDMI switchers just in case I ever need to connect 4K/120 or 8k 2.1 devices.
Brambo67
So is it safe to assume the revised AVC’s with the TI DAC’s can perform much better than many expected in this thread? It seems the PCM1690 doesn’t at all perform that much worse compared to the AKM’s.
Interesting picture from right after the 4700 and 6700 launch, it seems the 4700 MAIN DAC-board is similar to the one in the 4500. Clearly the pic from the DENON.JP site is an updated MAIN DAC-board (different lay-out) Still two 8-channel DAC’s it seems so 2 x PCM1690?
