digiface aes RME
morillon
Has anyone tried -measured the new "Digiface AES" RME???
thank you...
Blumlein 88
I don't know of measurements. However, when I've seen measurements of RME over the years, they meet the specs they claim. So I'd feel pretty safe with RME that they will either meet spec or come really, really close (or slightly exceed them).
morillon
morillon
but where is the interest in relation to a fireface uxc2? why such a price difference?
Blumlein 88
I don't know the answer to that. At first blush the Fireface UCX ii seems a better deal than the Digiface AES, but there may be other reasons.
Perhaps Matthias Carstens from RME can tell us what the use case for each is. He posts here from time to time.
@MC_RME
MC_RME
The Digiface AES is a very specialized unit, specced and designed based on broadcast requests, that is produced in very small numbers. That raises its price signficantly, It should be clear from the limited analog I/O alone that this is not the usual audio interface that will appeal to many.
morillon
morillon
to be honest I didn t understand how it is compared to the ucx2 ...
uxc simplified...
morillon
morillon
thank you
(I understand his interest.. but it is his tariff positioning that I did not understand ;-) )
MaxwellsEq
thank you
There are far fewer broadcasters than home audio enthusiasts or home recording artists. As a result, they don't expect to sell many. If development costs $100,000 and there are only 100 purchasers, they would need to charge $1000 per unit to cover costs. If there are 100,000 purchasers, they would only need to charge $1 to cover costs.
morillon
morillon
thank you so much for so precious explanation...
i m a little supid... ;-)
it's funny, it seems to me that this card could just be aimed at an ""amateur"" public not broadcaster and wider than the ucx precisely , perhaps in the end, I will only miss two asymmetrical outputs to be a "general public" hdg soundcard.... (if was located at a lower price than the ucx)
but ok...
i have ""explain""
paudio
Only the most expensive RME devices have a 12v trigger for instance. It's a nice feature to turn on other equipment.
Looks like low impedance headphone out first appears on Fireface UXC II. Everything else is 24ohm+. I like where RME is going with their interfaces.
Trell
It’s only the ADI-2/4 Pro that has a trigger out.
The new audio interface flagship UFX III does not have a trigger out.
Not really new. The UFX II has 2 Ohm headphone output and was released januari 2017. The brand new UFX III also has 2 Ohm.
paudio
True. Though the UFX are a much larger and much more expensive interface. The Babyface pro is a bit different format but does count.
Rja4000
Liège, Belgium
But you could use any output to send a DC voltage out (up to 9.5V, which should be enough. If not, it's easy to add a relay and a 12V PS)
