Dirac and similar
digicidal
Sin City, NV
Yeah that's what I figure... but as the post was preceded by:
The Speaker Boundary Interference Response or SBIR as depicted in my previous post. Or also that interference introduced at listener seat (by boundary interaction). I am sure this is very trivial knowledge here. I don't adjust for that in EQ, it is already fixed in speaker design and setup.
I found it a little confusing... but it is late and I am quite tired and maybe a little stupid (well a little more than normal I mean).
Thomas_A
Sweden
Can you pls post that graph with 1/12 smoothing?
Btw, it seems that panels you put behind your speakers didn't really prevent that dip at 80Hz.
No, and it should not, panels are designed for higher f. I can post with 1/12 smoothing but I am occupied at the moment, so later.
Krunok
Zg, Cro
It would actually be interesting if you can post measurements with and without rear panel (both with 1/12 smoothing) to see the difference.
Thomas_A
Sweden
Also the center of the mid woofer (80-3000 Hz) is 35 cm from wall, so the reason for the dip @ 80 Hz is not known at the moment. Since I am building new subs and will include parametric EQ <100 Hz I have not bothered yet with this.
Krunok
Zg, Cro
You didn't specify details about measurement you posted: is it showing onne or both speaker response? Is it a sweep or RTA? Was it made on a single spot or is it a spatial average?
It is hard to judge that dip without knowing if it occurs only at a isolated spot or throughout a wider area.
Thomas_A
Sweden
One speaker, 1 s sweep, single spot, listening position (the above one is an older one, I've made changes in the x-over since that, but that only affects some dB in the 1-3 kHz range). I will disconnect the subs and unplug the ports to use the top speakers to measure +/- panel and different wall distances; the will be good from 40 Hz and up. But it takes a while, these sweeps are neither really family- nor neighbour-friendly. :)
Krunok
Zg, Cro
LOL Very true! :)
I actually use RTA (pink noise) and move microphone around LP to get spatial averaged measurement. I use sweeps only when I need to correct phase.
Thomas_A
Sweden
This is another measurement made previously, left speaker, 1s sweep, listening position, one point. Now smoothed 12dB/octave.
Krunok
Zg, Cro
From 160Hz upwards it looks ok. Everthing below that I believe can be fixed with room EQ. Pretty much usual room related stuff.
That dip at 74Hz seems to be part of the wider depression in the 60-160Hz range. Below 60Hz response is obviously dominated by that huge peak at 46Hz.
Thomas_A
Sweden
i
Yep that basically summarise it but not sure yet if there is something else 100-200 Hz. The panels also loose capacity sharply in that region. I had other ones previously good to 100 Hz. But since I don't really have a sub worth being called a sub, I'll wait to work with Thebissues after that. The new ones will be tuned to 21 Hz. I used to have the 46-47 Hz peak tuned down when I had the Behringer parametric EQ. But that system is long gone now.
Krunok
Zg, Cro
i
Maybe that dip is not a result of cancellation because of reflection from the rear wall but from the other surface.
Anyway, I'm very curious to see measurements with and without rear panels.
Thomas_A
Sweden
Yes, I agree, this interesting. In the meantime, waterfall plots show that ≈47 Hz and ≈87 hz peaks show up. It is the same as the theoretical modes in the room. Other than that, rather clean.
Thomas_A
Sweden
Thomas_A
Sweden
Is that before or after EQ?
Thomas_A
Sweden
The reverbant in numbers;
Krunok
Zg, Cro
I just ran into this interesting paper from Dr. Geddes. Although it is about placing multiple subs it contains many interesting thoughts related to what we discussed here.
