Fighting room resonances with notch filters
ppataki
Budapest
I was reading an article about room modes when an idea came to my mind
We can fix frequency-related room modes pretty easily with EQ (either using REW or more automated solutions like Dirac Live, Acourate, etc.)
But once the frequency domain is fixed there can still be temporal resonances that remain there and they can be really annoying especially in the <100Hz range
This is the Dirac Live optimized frequency response of my L+R speakers:
I still have a huge room-related dip that cannot be fixed but the rest is OK in my opinion
Now if I take a look at the Waterfall diagram (using 400ms time range) I can see that there are some frequencies ringing more than the others:
Some of these are pretty nasty......
So how to fix these in the digital domain?
I thought I would try some notch filters - those are very narrow filters to remove the signal between two frequencies; basically a surgical EQ
I was using T-Racks Equal to make it happen and I decided that instead of completely removing the signal with notch filters I would just attenuate it with traditional bell filters but using very narrow Q (20) based on the Waterfall results above (at 42, 50, 66 and 98Hz)
Here is how it looks like:
Now let's see what it did with the Waterfall:
I would say this is quite a difference!
It also has an impact on the frequency curve of course:
The biggest difference is visible in the T60M curves......
And actually when listening to it it sounds way better! There are no more audible long decays but the bass is still there, it is just not annoying anymore
I fine-tuned it a bit more by keeping only those filters where the resonance was audibly most prominent and also I have realized that even a reduction of 2-3dB is enough to get rid of the annoying ringing.
Let me know your experience once you tried it - I hope it will help others too
boxerfan88
I am with you on this.
After much trial and error, 9 mths back, I landed on a similar approach of using steep high-Q notch filters to manage room resonances.
The only difference is that mine is done inside foobar2000 using MathAudio's PEQ. (I don't have Dirac).
Before (43Hz, 55Hz, 70Hz rings past 300ms even up to 750ms)
Notch Filter Applied
After (far less ringing past 300ms) sounds really good to my ears.
Shadrach
Wish I had seen this thread before I started mine on a similar topic.
I've been experimenting with notch filters and shelf filters. I'm interested in what can be done with a loudspeaker system rather than headphones.
Sometimes there are room nodes that are difficult to deal with due to the penalty dB drop in the preamp. Being able to attnuate a single frequency would be very useful if the frequencies either side could be left untouched.
