markus
- Joined
- Sep 8, 2019
- Messages
- 712
- Likes
- 824
And let me take the opposite posture. How can you confirm with REW that the results of the Dirac cal was accurate? You cannot because, unless you have a multi-microphone array, you cannot reproduce the same measurement positions. In order to get some idea of the effectiveness of the RC, you should compare the before/after with REW only.
If he would have measured all single points that were used in the DL calibration and averaged them in REW then the results should be very close.
If he would use only one single position for DL calibration and wouldn't move the mic for remeasuring with REW the results should be exactly the same. If not then there's something wrong.
