Dirac Live 3 vs. Manual Effort with my MCLA
P
ppataki
Budapest
@ernestcarl
I have set the Live Playback Latency to Minimum
Buffer is set to max in the ASIO driver of my Topping DM7
Here is the latency in DSP Studio:
And here is the delay of the filter itself:
To be honest I am not too much worried about the fact that I cannot use convolution
I am now going back to using some VST plugins (CraveEQ and CurveEQ) and again what I tend to conclude is that it sounds more 'lively' - there is no difference in the frequency response so I guess what I hear is attributed to differences in the time domain - I am yet to 'prove' that
I have been spending an awful lot of time trying different methods - as soon as I find the one that sounds (and measures) great I will share it
ernestcarl
of my Topping DM7
I would recommend to keep the former close to or exactly at default and the latter set to as low a number just right under the default as long as it plays "Live" without any long delays, stuttering or glitches.
6 seconds can show up during internal playback, but that is not relevant as what is crucial is the delay value shown during "live" playback. As Henrick (from JRiver) says: The second latency value has no meaning unless you are trying to synchronize live playback.
No problem. Though, people should know that they can indeed use convolution just fine without causing any perceptible delay. One just needs to utilize it in a more economical way. Say, purely as an experimental test example, I originally shown here.
Though, I did slightly modify the paragraphic EQ values for better off-axis performance around 15 degrees both horizontally and vertically:
Don't know if it would interest you at all, but I have ordered an FX50 unit that should be arriving today as well. I'm personally curious if the generic FIR EQ correction I modelled out from Amir's "golden" test unit is going to work well with my own.
P
ppataki
Budapest
Good point, thank you!
I will take a look at that later today
You are right, I shall also experiment with it further - I realized that if I do not touch phase but normal EQ only, then I can use centering = 0 and that will produce zero latency
See the IRs below using exactly the same settings except for the centering value
this is when using '0' (producing close to zero delay)
and this is when using 'middle' (producing the above mentioned >300ms delay)
These are just REW-RePhase simulations but will perform some measurements too later today
And one more very interesting phenomenon I realized - would appreciate any comments on this one since it is above my head
When I use EQ in REW I can have various strategies: decrease the target curve and use zero boost or I can keep the target high and use boosting EQ
I have realized that this has quite an impact on how the IR will look like!
there are some differences in the FR curves:
I wonder if that is the reason for the IRs to be different.....
see the animation showing the IRs in a loop (starting with the one with the red FR above)
I really wonder if this is only because of the difference in the FR curve, or by something else....
OCA
Germany
The latest REW (currently only early access from the link below) has new features added in trace arithmetic and it's now possible to create convolution filters with inversion without any EQ filters.
I have been getting consistently good results despite equalization on the entire frequency band (way above Schroeder's) and also uploaded a video tutorial (along with a link to a comprehensive text guide) explaining the method:
P
ppataki
Budapest
Thank you @Serkan, this is marvelous!!! I totally love it!! I have been waiting for this feature for years......
I will play around with it as soon as I have some time and will report my findings
Reactions: OCA
P
ppataki
Budapest
One quick question @Serkan: you manually do the IR time alignment in the video
Is there a reason for doing that instead of just simply using the Align IR Start button?
Thank you
fluid
The features in the insider version are a big leap forward for REW, the important item that is missing as far as I can see is the ability to vary the frequency dependent window length with frequency. This makes a big difference in programs that have it. The walkthrough and demonstration in the video is great, particularly for those without any experience. There were quite a lot of descriptions or choices where I found myself disagreeing, I don't want to drag your thread into a negative direction by listing them, but it felt wrong to avoid saying anything, so I suppose I would just caution to not necessarily copy everything seen or spoken about verbatim.
fluid
Maybe @fluid we shall devote a new thread for that discussion?
Would be really interesting
Maybe, but it could be hard avoid sounding negative towards Serkan (which is not my intention) unless the discussion was more general. Anyone who goes out of their way to provide useful information should be supported.
P
ppataki
Budapest
Hi @Serkan
I started playing around with this method (only simulations in REW for the time being; I will have time to actually listen to how it sounds later tonight)
One question: why shall we set the Target to 3.6 when doing the 1/A operation? Just trying to understand what I am doing
Then with regards to the IR alignment again: I noticed that in the end the MP version will have the IR start at 0 independently if I set that up manually to be at 0 at the beginning of the process
This is the MP correction IR for my left channel when not applying IR offset at the beginning:
and here is the MP correction IR when applying IR correction manually at the beginning of the process:
They are the same, no matter if I applied IR correction manually or not
Need to add that in the non-MP correction filters the IRs are indeed different but that difference disappears when I generate the MP versions so I am not sure if the manual alignment is necessary if we are going to use the MP versions at the end of the day
Can you please comment?
Thank you
Reactions: OCA
OCA
Germany
Thank you
Thank you
IR start can get it wrong sometimes but most importantly you will not see the exact fix REW is applying to be able to adjust your speakers accordingly and IR start doesn't necessarily move the IR peaks to time 0 which is handy for the vector calculations afterwards.
OCA
Germany
Guys, I am fully open to all sorts of comments and criticism. At the end of the day, this is an attempt to get the most out of a REW version which is still not even beta and I am not 100% certain of some of the steps either. I tried to share the steps which gave me the best results.
Hayabusa
Abu Dhabi
Method 1:
9-point measurement using a 'cube' with a diameter of 1 meter
Method 2:
1-point measurement with REW at 75dB for each channel
You wanted to compare apples to apples..
So why then 9 measurements in a cube for method 1?
Could this explain the differences in FR you see?
OCA
Germany
Hi @Serkan
Thank you
The intention is to check L&R distances to LP and correct them and no harm in adding the offset to the measurement while you are at it. It seems to be the same however there will be very small differences and they will be carried over in the IR windows ref time (as -0.000) of the impulses which will eventually create calculation differences especially in later stages. I haven't included excess phase reversion in the tutorial as it's still work in progress but inverted EPs are very sensitive to time inaccuracies for example.
OCA
Germany
Hi @Serkan
Thank you
Most vector calculations are actually done on the fft (fast fourier transformation) of the impulses and 0 db will give division by zero or infinity errors thus they are applied an offset which we need to compensate for. The exact number 3.6 was given to me by John Mulcahy himself :)
OCA
Germany
Very interested in that too, please let us know once available
It's quite ready and literally upgrades the overall sound by a notch but I have not been able to eliminate the pre-echo from high frequencies without using a combination of Octave, SOX and Audacity and still bit of hit and miss even with these tools. Once I come up with a REW solution I will happily share. Happy to discuss if anyone here has managed to do EP inversion successfully.
OCA
Germany
For starters SPL equalization explanation in the video is wrong (it equalizes a total of the octave value selected around the frequency), I have fixed that in the text guide but I cannot edit the published video.
fluid
That was one :) Most are like that, fairly minor in significance. The description of the Harman curve, targets and use of windowing would be the main things I see quite differently. Even though you're open to criticism (which is admirable) I don't want to say more unless ppataki wants the discussion here.
