theREALdotnet
- Joined
- Mar 11, 2022
- Messages
- 1,209
- Likes
- 2,084
if I pass 5.2.2 to avr, the avr will still need 2 discrete sub outs (not 2 subouts in parallel) for dlbc to work?
If it’s a 5.2.2 AVR then it would have two separate sub outputs, wouldn’t it? If it’s not then it would probably sum the two sub channels and output them through the single output. DLBC will still work with two subs summed as one, but you’ll lose a lot potential for good bass response in the room. You‘d also have to align them first manually, so that they don’t play out of phase with each other etc.
my htpc is windows with nvidia card. it seems Apple 3.5mm dongle will work with pc with uac (not sure what that means). Is that true? but I think I saw the need to aggregate dacs and it can't be easily done in windows? (I did see someone mention a freeware)
Sorry, I can’t help with Windows questions, I’m sure someone else will chime in. But yes, (for stereo) DLBC needs to see an output device that has as many inputs as L + R + number of subs. In macOS you would combine the USB DACs as aggregate audio device, which you’d then give to DLBC to output to.
