DIY Acoustic low-frequency conversion absorber measurements
ppataki
Budapest
I thought I would share my measurements about my first DIY conversion absorber
It is a plywood sheet attached to a timber frame and filled with damping material then attached to the wall
(the photo shows before totally filling it with damping material)
It is tuned at 68Hz
Let's see the measurements at listening position
Frequency response:
The red is with my HOFA natural bass traps, green is without them and blue is the conversion absorber. Close to zero differences below 100Hz, some differences between 100 and 200Hz
T60M graphs:
We can see that the HOFA does a way better job with broadband absorption above 100Hz but below 100Hz the conversion absorber performs slightly better
Waterfall diagrams:
No absorber
With HOFA
HOFA decreased the ringing above 80Hz but strangely it increased the ringing at about 70Hz
With the conversion absorber
Ringing at tuning frequency is reduced (but only compared to HOFA and not when compared to having nothing in the room). Ringing above 100Hz is not as effectively reduced as with HOFA
I must say that I am totally NOT impressed by the performance of the conversion absorber
Maybe I screwed up the build, not sure - anyway I was expecting some more impact overall
Any builds/comments/advice would be appreciated
Vict0r
The Netherlands
Thanks for that link! These seem very affordable to DIY. I still need some absorbers for my office, so I'm going to give this BBC design a try.
Geert
My impression is you didn't use the right type of absorber. You're supposed to use mineral wool, which is a material that allows air through. If I'm not mistaken the material you used doesn't.
P
ppataki
Budapest
I have concerns using mineral wool in a living room (health risks)
Are there any bio alternatives? Maybe combed wool would do?
Thank you
Geert
That's a valid concern. There a different specialised acoustic materials like Akotherm D40.
JPA
Burque
It's a little hard to tell from your picture, but it looks like the foam is in contact with the plywood membrane. You don't want that. The membrane has to have complete freedom of movement except where it's attached at the edges.
JPA
Burque
@JPA How could I prevent the filling from contacting the membrane?
You need to pull it away from the membrane so there is at least a 1cm air gap. It looks like you're using two layers. Try only using one layer to make room for the gap. If it is glued in place you'll have to cut it out and re-glue it.
I recommend reading the section on diaphragmatic absorbers in "Master Handbook of Acoustics" by F. Alton Everest.
