DIY measuring headphones
tvrgeek
North Carolinia
I thought I would take on some of the modifications to my Grado's. Why not. Old and not very expensive. I would like to be able to make relative measurements of their response and distortion. Would just a flat plate with my mic flush in it be a reasonable rig. Only need one side at a time, don't need to copy some generic ear as I am not looking for any absolute or comparable measures, just what my mod does. Thoughts?
Behringer mic, Foucusrite IO, etc.
voodooless
Netherlands
I guess you could 3D print an ear+canal and hook up your mic? DIY version of mini-DSP ears. The main question is how you can properly calibrate the contraption, but that might not be your primary concern for now.
You could even 3D scan your ear ;) Try something like Polycam.
tvrgeek
tvrgeek
North Carolinia
WAY too complicated for a simple one time relative test. Another forum suggested some felt on the board to reduce reflections.
Earfonia
Singapore
I used Primo EM172 and EM258 before for binaural mics, they sound very good with very good bass and treble extensions. I also tried EM172 for IEM comparison measurement, very usable. Since you just need comparison measurement I guess the new Primo EM272 will do the job very well. EM272 is the replacement for the no longer in production EM172.
You can use Apple USB-C dongle for the headphone output and mic input. Just need a splitter to split the headphone output and mic input.
It was just past experiment, my IEM measurement rig now has been upgraded.
tvrgeek
tvrgeek
North Carolinia
I used to have a Panasonic capsule. My first mic. Gave it away when I bought the ECM8000. ( Which now has a noise problem)
For a ear bud, I guess sealing it in like that would work pretty well.
