Tom C
That’s exhaustively detailed. At least I’m exhausted.
Glad I could be of assistance. Here is another argument you may not have heard, have you considered that plastic lined, anti-static sleeves might do more harm than good, by providing no absorption (as paper does) to changes in humidity and allowing it (humidity) to sit, trapped on the surface of the record, neither absorbing nor evaporating. It is probably no big deal, but in a humid environment I would stick with paper sleeves.let me say that i never ... never listened to that kind of arguments.
In what way. Yeah, the first time there is little bits of paper, just brush them off. Paper is more environmentally friendly than plastic and none of the records I have are any worse for being in paper sleeves, many have been in them for years from new.I cannot recommend the Nagaoka sleeves enough, the stock paper sleeves are garbage.
My room is a dedicated studio and my turntable has a lid which is always down when playing a record. Beyond that, if brushed before playing, dirt and dust just simply isn't a problem, and I've been doing it for decades. Believe or not it is possible.I can't believe the number of responses here from people that don't clean their records, lol. Most records are unlistenable after a few plays unless you are living in a laboratory clean room.
The mere act of playing induces static into the lp which makes it a literal dust magnet. You will never be able to completely remove that electrically-bonded dust with a brush. Also some new presses are positively grubby with (releaser?) contaminates. I've only been collecting records for about ten years though. Perhaps as a child of the compact disc era, I have a lower tolerance for controllable noise contamination.My room is a dedicated studio and my turntable has a lid which is always down when playing a record. Beyond that, if brushed before playing, dirt and dust just simply isn't a problem, and I've been doing it for decades. Believe or not it is possible.
Nope, records I play are usually very silent except for ticks which are on the record from the day the disc is new. It's not that I'm getting used to noise or can't hear it. Don't wouldn't assume that your experiences extend to anybody else in particular because you're bound to be wrong more times than you're right!The mere act of playing induces static into the lp which makes it a literal dust magnet. You will never be able to completely remove that electrically-bonded dust with a brush. Also some new presses are positively grubby with (releaser?) contaminates. I've only been collecting records for about ten years though. Perhaps as a child of the compact disc era, I have a lower tolerance for controllable noise contamination.
Indeed. One man's 'pretty clean' is another man's practically unlistenable. There is nothing subjective about the results from a good ultra sonic cleaning however. It was a revelation, not the least being the ease and complete removal of all static electricity. I have brushes- even the one with the radioactive isotope- they can only do so much.I don't find that to be the case. If a record plays pretty clean then just the occasional brush before playing seems fine, without need for cleaning.
But this of course enters the realm of the subjective and what one person will tolerate vs another.
I don't see any subjectivity there at all. Either a disc is noisier than it was or it isn't. In my case, I know how much noise there is and where the ticks are. Maybe I have an exceptional memory - who knows. But there just isn't an increase with repeated plays. I have valued discs from the late 1960s and they are the same as when new (I know this because I tape recorded some of them back then and can directly compare).Indeed. One man's 'pretty clean' is another man's practically unlistenable. There is nothing subjective about the results from a good ultra sonic cleaning however. It was a revelation, not the least being the ease and complete removal of all static electricity. I have brushes- even the one with the radioactive isotope- they can only do so much.
