Do my Sundaras need more power or are they just faulty?
jawbfl
Morocco
Yes. If both amplifiers are capable of delivering the current drawn by the load at a given output voltage (volume dependent) and both exhibit low output impedance (less relevant to Sundara), noise and distortion will be the factors which determine whether the amplifiers can be distinguished from each other.
I read experiences of people on a laptops have to push the volume way high to make Sundara sound better, that's definitely the case for me, on max volume it's painful but it sounds muddy, for those people using a decent amp they don't have to push volume and they say it's a major improvement in sound stage, low end performance etc (can't personally confirm), @holicst experienced similar issue.
In practical terms, almost any modern source will exhibit noise and distortion below the threshold of audibility.
If noise isn't the factor here, how do you explain this behavior?
Jimbob54
Differentiate source from amp. In the macbook example there is a DAC converting the digital stream (source) then an amp stage- you are probably driving the amp to clipping and/or distortion at max. If you instead used the macbook into the Atom and let the Atom do the heavy lifting- no clipping or increased distortion.
Weeb Labs
Ireland
You are most likely clipping the output.
At low volume levels, the equal loudness contours significantly reduce the amount of audible bass and higher frequencies. This can give rise to the perception that an amplifier with relatively low voltage swing is “anemic”, as low frequencies will then also be the first to clip when volume is raised. Output measurements would be needed.
Otherwise, this is a sighted observation and may disappear under controlled ABX conditions.
Weeb Labs
Ireland
Do you still think this statement is correct?
With respect to my preferred listening levels, yes. There is no doubt that were I to run all of my sources at maximum volume into the Sundaras, some of them would clip.
As mentioned previously, this is highly dependent upon one’s listening levels.
sandymc
I have a the Hifiman/Drop HE5xx. Very similar sensitivity to the Sundara, but about half the impedance (18 vs 37 ohms). They sound ok driven straight off my iPad. There's no audible distortion, but the volume does have to be set quite high. They do sound better - a bit fuller - driven from a Topping stack, but the difference isn't enough that you'd think there's any problem.
jawbfl
Morocco
Thanks, I use it on the macbook at ~60% volume and I really hope it will sound better once I get an adequate amp because I'm not 100% satisfied with the sound.
Weeb Labs
Ireland
The discussion has thus far centred around amplification but have you considered that the Sundara’s natural frequency response simply might not be to your preference?
I would suggest having a look into EQ (specifically Oratory’s profiles), if you have not already. The Sundara does exhibit a slight low frequency roll off by default.
Nango
D:\EU\GER\Rheinhessen
Is HE-560 V4 (ridiculous offered now at 269$!!) tonally more an HE-500 than a Sundara ..... or has nothing to do with?
jawbfl
Morocco
I got it because it follows same response of M50x which I liked but more flat, it's not that I'm disappointed, I just want a bit more sound stage and resolution which I think need more power and lower noise/distortion, I might EQ the low end a bit, on some tracks I just want a fun sound rather than pure fidelity.
Weeb Labs
Ireland
Perceived soundstage is unrelated to amplifier power output but I would encourage you to try other sources regardless, given that we have no data for this particular output.
As I’m sure you are aware, many owners of this headphone use them in conjunction with phones, dongles and laptops without encountering such problems.
jawbfl
Morocco
Yeah some say soundstage is more related to noise floor, I'm not sure but at a higher volume I feel it's wider.
Another question I had, M50x has an impedance of 38ohm, Sundara has 37ohm, why the Sundara requires much more volume level on the computer? sorry for asking so many questions.
Jimbob54
Sensitivity.
Specifically Sundara is 94dB ( I assume both of these are for mw, neither manuf states) and M50 is 99dB so for the first mw, the M50 is 5 dB louder. For the same position on the volume knob, the M50 will be louder.
EDIT- even better, what @solderdude says just below.
solderdude
The Neitherlands
to be more precise... voltage sensitivity.
Sundara = 108dB/V
M50X = 117dB/V
The M50X is twice as loud at the same volume setting than Sundara so more..
Tigi
Czechia
If I deduce correctly, the amplifier should deliver about 2.82 times higher voltage to the Sundara to achieve the same SPL as M50X (dB Voltage = 20 log (V1/V2)). Which is definitely not a small amount.
Weeb Labs
Ireland
Driving a headphone with a sensitivity of 108dB/V and an impedance of 37 Ohms to 117dB would require 2.82V (at 76mA for 215mW). You can find a handy calculator here.
Jimbob54
Ignoramus question, how do you know /work out the current draw? I see 50ma quoted, you say 76 here. Is it fixed by the amp and only the voltage varies or do both vary depending on cans and volume knob?
Tigi
Czechia
Power = Current x Voltage = Current x Current x Impedance = (Voltage x Voltage) / Impedance
Weeb Labs
Ireland
You can determine the current by applying Ohm's Law. If we know that the output voltage is 2.82V and the load is 37 Ohms, then we can plug those values into the equation.
I = V / R
And therefore:
2.82 / 37 = 0.076A or 76mA
