- Joined
- May 1, 2021
- Messages
- 428
- Likes
- 1,314
Here are the on-axis magnitude level responses for a perfect second-order (acoustic) crossover (2,5 kHz) with 1) two perfectly distance-aligned drivers, 2) 1 inch offset between drivers, equivalent to a pure delay on the 'further back' driver, and 3) a second order Bessel allpass compensation on the other driver:
The allpass filter is enough to almost fully compensate for a pure time delay up to 10 kHz or so. For larger distance difference, a second-order allpass filter will have trouble compensating enough. And the type/order of crossover and crossover frequency will also be important. And then there is the implementation of the allpass filter to consider, as a passive version will come with its own problems. And one should also check off-axis responses. I can add step response also, but the LR2 will itself distort such an input, so maybe not of much relevance.
