- Joined
- May 4, 2022
- Messages
- 521
- Likes
- 573
I have two speaker positions I use.Then you have a bit of asymmetry in the setup. If possible and with "permission" I would look if there is any way to alter position of things such that the coffee table blocks the floor reflection only and not act as first reflection from the speaker to ear. It seems that the right speaker is rather close to the coffee table to get such reflection?
In the wife friendly position, primarily used for background music, the speakers are pushed back against the wall, and the right speaker is near a corner. The coffee table is about equidistant between the speaker and where I sit. I have two Direct Live profiles set for this position using their "wide imaging" arrangement.
In the wife unfriendly position, used when she is not around and I want to just sit down for a listening session, I will pull the speakers about 55 cm from the back wall and move the right speaker further away from the staircase on the right, so it is just near the table right-back corner, which I often cover with a blanket (on a couple of occasions I actually moved the table, but it is a bit heavy). This puts the speakers equidistant from my listening position. I have two Direct Live profiles for this position set using their "focused imaging" arrangement.
