And that is a silly omission in some (but not all) cases. But those that lack phase info should say "magnitude of FFT", not "FFT"
Sometimes ^they^ say spectrum…which is perfectly fine.
The point is.. that most people use only the amplitude/magnitude
And the second point/.. is that the flatness of, say a pink noise spectrogram, is coveted “Uber Alles”… and the only thing many want to see.
about the only time phase is mentioned, and shown, is in a speaker’s complex load.
very seldom it is seen in measurements of the resulting pressurisation.
Obviously you aren't familiar at all.
You may have the same POWER SPECTRUM, but you will not have the same phase spectrum in such a case.
FFT's have complex results. It's not just an amplitude or power spectrum. You will find, plainly, that two different impulse responses will have different complex spectra.
Magnitude spectrum is only half the data.
The whole point of this thread topic is about phase, and whether it matters.
And I have harped that people look at the magnitude and either smile or frown.n
Agreed, but as stated before, as long as you dont sacrifice other known audible characteristics, which often is the case.
That is kinda the discussion here… how do we rank them?
do we even want to?
I think that it is important (at least to me)…
The title has in it, “does phase even matter”
Many/most stop at the flatness of the spectrum
Toole, and others, also say it is not important.
I suppose that the hairs in the ears do not know whether they are getting pushed or pulled?
But it seems like would be like seeing a tsunami come in without the water first receding.
and saying the the phase flipped tsunami is equivalent to a real tsunami.
Physically, the direction of the sound pressure seems like it should be true to the signal, if we want to call it fidelity.
But I agree that trading lots of IMD, or other distortions would be agreed to be lower fidelity for more people.
And it is hard to mathematically compare the measured sound against the electrical signal when the phase is flipped…
One sort of needs to use only the magnitude, if they want to ignore the phase.
