Keith_W
- Thread Starter
- #101
You should post uncorrected response of each channel with either 1/24 or 1/12 smoothing and with a resolution on the Y axis with 5 dB. And waterfall of both channels from 15 Hz to 400 Hz. You could also measure at stomach and feet height and post the waterfall of this. All uncorrected.
All right, this is the UNCORRECTED response of the entire speaker. Bear in mind this is a 3 way active speaker with 2 subwoofers, i.e. 4 channels per side. The reason it looks so lumpy with huge discrepancies between the drivers is because there is no levelling, no room correction, nothing. If you want individual driver measurements, I can provide those as well. Just ask
And this is the waterfall that you requested. Again, uncorrected.
And here it is with all corrections. Note that all the huge dips seen in the Acourate plot are missing. This is probably because with Acourate, I apply a FDW (freq dependent window) only to smooth it, I don't know how to replicate REW's 1/12 smoothing in Acourate. The reason the bass is a tiny bit more lumpy than Acourate's is because the Acourate measurement was taken without moving the mic after performing the initial sweeps for input. These REW plots were taken on another date.
And here is the waterfall, with corrections. Note that I didn't calibrate the microphone to the SPL meter, which is why the noise floor is so high (70dB) and the measurement peak is at "130dB". It is not, if it really was 130dB I would have fled the house. I have provided a generous 1000ms window so you can see how long the fingers are.
And here is the spectro for good measure:
All measurements were taken with a microphone tripod at the main listening position.
@mcdn I can't do a MMM right now, because my interface has been lent to a friend. When I get it back, I will do the MMM. I rummaged through my collection of old REW plots and I can't find my MMM because it is buried like the proverbial needle in a haystack. I found dozens of .mdat's and it's there somewhere, if I happen to find it I will post it. I should have labelled those sweeps properly!
@ppataki I managed to try the settings you recommended for the Pultec EQ. This has gone a LONG WAY towards improving the bass. I found that setting the bass freq too high (80Hz) resulted in overwhelming, bloated bass. I have set it at 30Hz, Boost 3dB, Cut 3dB. This way the effect is subtle. I will work on fine tuning the settings the rest of the evening. If I like the effect, I will bake it into the target curve.
