DSP Measurements and Rising Noise Floor
spalmgre
Helsinki
Neurocrome Modulus has been tested at ACR so we know what that represents. Modulus is in my opinion too expensive or let's say that I can not see the added value over a done right version that somebody else has done.
The "Doner right" and several other boards can also work well as there is a lot of good information to find how to develop a working amplifier using the LM3886 chip. Here is a non-China board by Eltim.
I did ask Connex Electronics are their board using genuine chips and quality parts.
This was their answer:
"Hi, We buy parts from reputable suppliers, and up to this date we haven't had issues with LM3886 ICs. The fact that is genuine or not has little to do with noise but a lot more with reliability. Fake chip will undeliver, and possibly blow up when reach the rated power. Probably noisy, but I haven't tried one yet."
I did not buy their LM3886SMPS at that time that I got their answer in 2020. But now I have ordered as they do sell the board without the LM3886 and I have found genuine such to fit myself. This adds up one of the cheapest solutions to get a amplifier that might fill my need for low noise level with my speakers.
M
mdsimon2
Detroit, MI
As a result of this thread Tony from miniDSP reached out to me unprompted and gave me an updated firmware for the 2x4HD to test out.
This firmware implemented two improvements: 1) changed the gain structure so volume control acts before ASRC meaning you can use attenuation in the miniDSP to eliminate intersample over clipping and 2) modified IIR assembly code to improve performance with low frequency EQ. As I understand similar firmware improvements are available for the Flex/SHD/DDRC-24 platforms.
Starting with sending a +3 dBFS 11.025 kHz tone to the miniDSP without volume control. At 0 dB volume position we see intersample over clipping as expected.
However with the new firmware at a volume control position of -3 dB you no longer get clipping.
-0 dB: Input RMS 1.09 dBFS, THD: N/A based on 0 harmonics [20..22000 Hz], N: -35.6 dB [20..22000 Hz], THD+N: -35.6 dB [20..22000 Hz]
-3 dB: Input RMS -0.27 dBFS, THD: N/A based on 0 harmonics [20..22000 Hz], N: -125.0 dB [20..22000 Hz], THD+N: -125.0 dB [20..22000 Hz]
Testing the applied filters shows some decent improvement across the board.
Sub - 2x4HD - 10 dB noise improvement with new firmware
Base OLD: Input RMS -1.03 dBFS, THD: -146.3 dB based on 49 harmonics [20..22000 Hz], N: -129.5 dB [20..22000 Hz], THD+N: -129.5 dB [20..22000 Hz]
Base NEW: Input RMS -1.03 dBFS,THD: -145.9 dB based on 49 harmonics [20..22000 Hz], N: -129.6 dB [20..22000 Hz], THD+N: -129.5 dB [20..22000 Hz]
Sub OLD: Input RMS -7.33 dBFS, THD: -123.6 dB based on 49 harmonics [20..22000 Hz], N: -108.0 dB [20..22000 Hz], THD+N: -107.9 dB [20..22000 Hz]
Sub NEW: Input RMS -7.33 dBFS, THD: -135.5 dB based on 49 harmonics [20..22000 Hz], N: -118.2 dB [20..22000 Hz], THD+N: -118.2 dB [20..22000 Hz]
Low - 2x4HD - 13 dB noise improvement with new firmware
Base OLD: Input RMS -1.03 dBFS, THD: -145.6 dB based on 49 harmonics [20..22000 Hz], N: -129.5 dB [20..22000 Hz], THD+N: -129.4 dB [20..22000 Hz]
Base NEW: Input RMS -1.03 dBFS, THD: -146.3 dB based on 49 harmonics [20..22000 Hz], N: -129.5 dB [20..22000 Hz], THD+N: -129.4 dB [20..22000 Hz]
Low OLD: Input RMS -5.38 dBFS, THD: -143.7 dB based on 49 harmonics [20..22000 Hz], N: -102.9 dB [20..22000 Hz], THD+N: -102.9 dB [20..22000 Hz]
Low NEW: Input RMS -5.39 dBFS, THD: -149.1 dB based on 49 harmonics [20..22000 Hz], N: -115.7 dB [20..22000 Hz], THD+N: -115.7 dB [20..22000 Hz]
High - 2x4HD
Base OLD: Input RMS -1.01 dBFS, THD: -145.8 dB based on 21 harmonics [20..22000 Hz], N: -129.6 dB [20..22000 Hz], THD+N: -129.5 dB [20..22000 Hz]
Base NEW: Input RMS -1.01 dBFS, THD: -146.5 dB based on 21 harmonics [20..22000 Hz], N: -129.6 dB [20..22000 Hz], THD+N: -129.5 dB [20..22000 Hz]
High OLD: Input RMS -10.75 dBFS, THD: -144.1 dB based on 21 harmonics [20..22000 Hz], N: -121.8 dB [20..22000 Hz], THD+N: -121.8 dB [20..22000 Hz]
High NEW: Input RMS -10.75 dBFS, THD: -143.3 dB based on 21 harmonics [20..22000 Hz], N: -121.9 dB [20..22000 Hz],THD+N: -121.9 dB [20..22000 Hz]
2x4HD FW 1.6 - Sub - 30 Hz
2x4HD FW 1.6 - Low - 100 Hz
2x4HD FW 1.6 - High - 1 kHz
Overall some really nice improvements in performance and love that they reached out and fixed this issue unprompted.
Michael
GWolfman
Question is @mdsimon2, do you like your LXmini?
I heard one version in person once (had the two dual-woofer subs) and it had a very interesting sound the seemed to fill the entire room. I wanted to listen more but wasn’t able to make it back.
GWolfman
However with the new firmware if you add 3 dB of attenuation you no longer get clipping.
High - 2x4HD
Michael
Fantastic work, thanks!
Still room for miniDSP to improve though (particularly low frequencies).
M
mdsimon2
Detroit, MI
Yes, I built them in late 2020 and really like them. They are definitely a bit volume limited but I don't listen loud. I wouldn't run them without subs as they become even more volume limited due to the low frequency bass boost that exists in the default EQ.
Overall I think Erin's review is pretty spot on -> https://www.erinsaudiocorner.com/loudspeakers/linkwitz_lx_mini/. They project a large sound stage and sound very natural to me. I think part of it is that they don't look like normal speakers but I've had several people ask if the sound is coming from the TV because they disappear acoustically.
The main A/V source in my living room system is an AppleTV and my wife and I listen to all TV/movies/music with them. I find them exceptionally good at producing clear dialog on movies/TV which is the primary reason they have stuck around in the living room.
They are also the easiest DIY speaker I have ever built, especially if you buy the wood parts from Madisound. Because I like them so much I do plan on building some other speakers with a small full range coupled to a woofer (FAST) with some Scanspeak 10Fs I have laying around but have not got around to it.
Michael
MCH
High - 2x4HD
Michael
Well, i guess the question now is if and when the firmware will be available. I would assume that obviously it will, but did they mention anything regarding that?
Thank you to bring this up and help solving it.
Sokel
High - 2x4HD
Michael
That's really good news!
And I'm glad I was the cause,despite the suspicion my newbie measurements raised at the beginning.
djwkyoto
Berlin
This is a really great outcome for your work, thank you so much. Kudos to MiniDSP for reaching out to you, though I wonder why they didn't catch it during their testing.
Really looking forward to the new SHD firmware.
Mnyb
Sweden, Västerås
Stupid question from the peanut gallery here :)
Firstly, thanks for this tread and further enlightenment about these kinds of product. This whole tread makes an interesting read .
Questions:
Is the mini DSP SHD Studio now an “OK” product to buy with the latest improvements. I have it on my shortlist for future upgrades working as preamp and DAC and DSP .
The latest fixes regarding intersample overs with the ASRC made me question how this thing actually works.
How does the signal chain looks like inside the software ?
In short is the volume control applied before any crossover or eq is applied ? Is this ok ?
Would you not want to run the DSP functions and crossovers on a full scale signal and then apply volume adjustments before the DAC stage ( or in the DAC chip itself).
You still want some input gain adjustments to cope with intersample overs of course .
As it looks from the outside is the volume is applied then you do the crossover and DSP functions ?
I’m a bit miffed that there are errors from the “mathematical functions” actually peaking above the physical noise floor ?
Is it not 2023 would not the whole number crunching be done in 64 bit floating point and we could forget about precision in algorithms altogether. I thought this was a 1990 problem with embedded CPU’s resorting to integer maths
M
mdsimon2
Detroit, MI
Questions:
Personally I don't think the issues observed here were ever of great concern from an audibility perspective.
I haven't tested any of the SHD series but I imagine they have similar issues to the other SHARC based platforms. Maybe someone else can confirm? No additional equipment other than the SHD is required.
Previously it was clear that volume control occurred after the ASRC, but we don't exactly know where in the chain. Now the volume control acts in front of the ASRC. Given all of the SHARC DSPs operate using 32 bit floating point I don't think there will be much difference where the volume control occurs but I can test this by comparing the results of applying attenuation in the miniDSP to the sine sweeps I've already done.
Michael
holbob
Lincoln, UK
How would somebody apply this attenuation in the dirac based minidsp devices (dirac takes over the input channels)?
Reactions: MCH
M
mdsimon2
Detroit, MI
Master volume control.
It seems only the gain structure related to the master volume control changed. Attenuation applied to the input / output channels will still result in intersample over clipping if fed a +3 dB tone with no attenuation applied via the master volume control.
Michael
Mnyb
Sweden, Västerås
Michael
Ok my current DSP preamp consist of a Meridian G68J that I’ve used for almost 19 years now it’s probably not better than a mini DSP :) however it has balanced outputs that was not a feature of the G68 ADV amid tested .
It has five Motorola 56367 processors probably with more artefacts than the sharc platform.
Currently I’m using it digital only ( except for the sub ) with Meridian speakers but I have used the analog outs for a couple of years
little-endian
The CD Player of course doesn't have any kind of volume control
Anyone got an idea about the CD player?
Some CD-Players such as the Technics (SL-PS740A) allow to attenuate the output level which includes the S/PDIF-output in 1dB steps from -12dB and 0dB, at the latter setting being nicely "bit perfect" which unfortunately isn't guaranteed by all devices either.
Can't say though how good the algorithm is for the gain control. Given the age, it will hardly be based on some super-duper 32-bit floating point and whatnot calculation.
ppp000
Thanks for your hard work Michael, brilliant topic, was hoping someone will do something like this. I have seen your other topics and made buy diyinhk 8 channel dac + aliexpress sharc dsp as minisharc is hard to get, and what you done is very helpful.
Would be lovely to have ADAU1452/66/67 for comparison how they doing in FIR filtering (is double precision even possible like with IIR?) as they are cheap like $50 boards on aliexpress, flexible - all the settings in sigmastudio, no need for costly JTAG or C programming, many functions can be controlled by external MCU over i2c... just big question for me - how they perform:) IIR seems impressive, but IIR is not why we get DSP:) If it can handle FIR, think it would be good alternative to miniSHARC, or even much better product.
Davide
Milan, Italy
Here are some consistent tests of the MOTU Ultralite Mk5 and Okto dac8 pro. I had previously stated the MOTU Ultralite Mk5 was clipping with no attenuation but this was not the case, rather I had incorrectly set the sensitivity on the ADC (doh!).
First the MOTU Ultralite Mk5. This is TOSLINK output at 44.1 kHz playing the same +3 dBFS 11.025 kHz that was provided by @Sokel into the MOTU and then routed to the MOTU TOSLINK output and captured by the UR23 TOSLINK to USB card. This is perfectly clean and shows the correct +3 dBFS level.
65536-point spectrum using Blackman-Harris 7 window and 8 averages
Input RMS 3.00 dBFS
-2.1 dBFS C, -0.2 dBFS A
3.0 dBFS 22 - 22k UNW
Distortion at 11,025.0 Hz, 3.0 dBFS:
HHD: N/A [10 .. 9]
N: -148.8 dB [20..22000 Hz]
N+D: -147.7 dBFS A
THD+N: -148.8 dB [20..22000 Hz]
Playing the same signal into the Okto but recording using the Okto as a capture device gives the same clean result.
Input RMS 3.00 dBFS
HHD: N/A [10 .. 9]
N+D: -147.6 dBFS A
To me these results are expected as neither device has an ASRC on input.
Now looking at the DAC output, first with the MOTU Ultralite Mk5 and no attenuation in the DAC. These are recorded via a Cosmos ADC at the highest input level. The spectrum looks clean but the noise floor has raised quite a bit.
Input RMS -0.57 dBFS
-5.7 dBFS C, -3.8 dBFS A
-0.6 dBFS 22 - 22k UNW
Distortion at 11,024.8 Hz, -0.6 dBFS:
HHD: N/A [10 .. 9]
N: -95.1 dB [20..22000 Hz]
N+D: -96.9 dBFS A
THD+N: -95.1 dB [20..22000 Hz]
Okto looks the same with a clean spectrum but elevated noise floor.
Input RMS -5.79 dBFS
-10.9 dBFS C, -9.0 dBFS A
-5.8 dBFS 22 - 22k UNW
Distortion at 11,024.8 Hz, -5.8 dBFS:
HHD: N/A [10 .. 9]
N: -90.5 dB [20..22000 Hz]
N+D: -97.5 dBFS A
THD+N: -90.5 dB [20..22000 Hz]
And now moving on to applying -3 dB attenuation using the DAC volume control. First the Ultralite Mk5, now the noise floor drops significantly and we see the expected result.
Input RMS -2.15 dBFS
-7.3 dBFS C, -5.4 dBFS A
-2.1 dBFS 22 - 22k UNW
Distortion at 11,024.8 Hz, -2.1 dBFS:
HHD: N/A [10 .. 9]
N: -115.1 dB [20..22000 Hz]
N+D: -118.7 dBFS A
THD+N: -115.1 dB [20..22000 Hz]
And same thing with the Okto, drop the level by -3 dB and noise floor drops significantly.
Input RMS -7.36 dBFS
-12.5 dBFS C, -10.6 dBFS A
-7.4 dBFS 22 - 22k UNW
Distortion at 11,024.8 Hz, -7.4 dBFS:
HHD: N/A [10 .. 9]
N: -112.8 dB [20..22000 Hz]
N+D: -121.5 dBFS A
THD+N: -112.8 dB [20..22000 Hz]
So overall these two devices behavior similarly. The receivers are able to take the +3 dBFS 11.025 kHz input without clipping, without attenuation they show an elevated noise floor but no severe clipping and applying -3 dB in the volume control lowers the noise floor to the expected level.
Michael
One thing is not clear to me (my ignorance).
How do you see that the analog signal coming out of the Mk5 doesn't clip hard?
Can you post the waveform measured with Cosmos ADC?
M
mdsimon2
Detroit, MI
On a FFT clipping looks like this. Harmonics and intermodulation of those harmonics increases drastically. The FFT gives you more info than the waveform.
In comparison the MOTU Ultralite Mk5 only shows an increase in noise floor from -115 dB to -95 dB when driven with intersample overs, there is no increase in harmonics.
MOTU Ultralite Mk5 11.025 kHz +3 dB with 3 dB attenuation
HHD: N/A [10 .. 9]
N+D: -118.7 dBFS A
MOTU Ultralite Mk5 11.025 kHz +3 dB with 0 dB attenutation
HHD: N/A [10 .. 9]
N+D: -96.9 dBFS A
Michael
Davide
Milan, Italy
In comparison the MOTU Ultralite Mk5 only shows an increase in noise floor from -115 dB to -95 dB when driven in to intersample over clipping, there is no increase in harmonics.
HHD: N/A [10 .. 9]
N+D: -118.7 dBFS A
HHD: N/A [10 .. 9]
N+D: -96.9 dBFS A
Michael
Ok, thank you!
So volume control on the Mk5 is acting before ASRC and if lower enough (< -3dBFS) can prevent ISP, correct?
M
mdsimon2
Detroit, MI
Ok, thank you!
The Mk5 doesn't really have an ASRC in the way that a miniDSP has an ASRC that can adapt a wide range of sample rates to a single internal sample rate.
I presume they are using the internal ASRC of the ESS DACs and the volume control clearly acts before that. If you want to avoid intersample over clipping just dial in a few dB of attenuation in the volume control. Fortunately the Mk5 has plenty of output level so knocking off a few dB is not a big deal.
Michael
