DTS Master Audio (Blu-Ray disc) vs SACD
MasterApex
For the same recording , say the John Williams orchestra music, do I get the same sound details and dynamic between DTS MasterAudio (blu-ray) and SACD?
mansr
Hampshire
DTS-MA will probably have less ultrasonic junk, unless the recording was originally made in DSD64.
shawnsingh
Just a side comment - you may already know. If you choose DTS MA, make sure your receiver explicitly supports DTS "Master Audio". If it supports "DTS" generally, that may not be enough. An older DTS player can still play DTS Master Audio files, but it will only use the legacy-compatible part of the file, and that part will actually be lossy encoded. The "Master Audio" part of the stream is needed to make it lossless, but would be ignored by older DTS players.
