Dumb Question - multiple pairs of speakers.
TrevorD
My gut tells me this is the most stupid question ever asked on an audio forum but here goes......
The following is a fictional example:
Lets say I have pair of bookshelf speakers - reasonable SQ - cost around US$300 from a good brand. There is little problem though, they have a sound hole lets say at around 3khz, maybe due to crossover deficiency or driver capability.
I have another, smaller pair of speakers that could fill that gap well. I have an amplifier that I could connect all 4 speakers to and control the volume to each pair separately to try and get a more level frequency response. Not trying to do surround sound here, just 2 pairs of speakers on each side of the room in front of me.
Would it be worth while trying this to see what the outcome is or are there some very obvious reasons this will just not be worthwhile?
Reactions: CMB
thewas
From theoretical point of view it is not worthwhile as you will create an interference mess but if you like to experiment, why not? I would recommend though rather using an EQ to partially fill that dip. Would you mind sharing which loudspeakers these are, as sometimes they have such a dip on-axis which gets less though off-axis and filling it might increase the radiated sound power in that region too much.
TrevorD
TrevorD
I was expecting that using EQ would be suggested as a better approach, and that makes sense to me with my limited knowledge of this.
When you say "create an interference mess", does that mean the drivers in different cabinets are not going to be creating soundwaves in sync with each other?
This is a fictional scenario, but the speakers I have are a pair of 20 year old bookshelf 2 way Missions. I will replaced them with either a new set or I am quite interested in building my own.
thewas
Yes, since you cannot filter them extremely steeply the drivers will be playing both the same frequencies and there will be constructive and destructive interference causing comb filter effect outside the optimal addition axis.
Reactions: CMB
TrevorD
TrevorD
OK - I get that. Thanks for the video link.
Time for me to learn about speaker/room analysis and equalisation next methinks.
Sancus
4 speakers, even in front, is actually a form of multichannel(just not a commonly used one).
I have to admit, any time someone wants to try something like this, I feel they'd just be better off with surround upmixing. That is actually a good way to hide flaws in speakers based on the research. And you don't have to worry about interference caused by feeding identical signals to so many speakers.
Reactions: CMB
dasdoing
Salvador-Bahia-Brasil
if you do something like that they should be stacked, not side by side. that way you move the cancelations to the vertical plane
Reactions: CMB
