staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,184
- Likes
- 13,152
Thanks but it's already off. No processing of audio at all.Try disabling the UHQ upscaler:
I have the same problem as yours. Plus I get micro stutters when playing music with every app that use the Android audio drivers. (No micro stutters with UAPP). On galaxy s22 ultra I have both the dropouts when switching from an app to another AND the micro stutters. On my LG v20 (android 9) only the micro stuttersI will try switching from "Allow sound and vibration" to "deliver quietly" and see if that helps.
The 9038D is not too powerful for the 3XR in the sense that there shouldn't be any hiss/background noise.Would this device be a good fit for my new Etymotic ER3XR with Sensitivity: 102 dB @ 1kHz, 1mW, or is it too powerful for that
You can use the 9038D with external headphone Amps.Just remembered I Have a Schiit Magni 2 Headphone Amp lying around. Would it work well with the E1DA 9038D as DAC, Magni2 as Headphone Amp for my Etymotic?
9038D works fine with the Ety- more likely to get some hiss from the Magni though but you can try both. Yes the 9038D can do the job as just a DAC.Question from a newbie.
Would this device be a good fit for my new Etymotic ER3XR with Sensitivity: 102 dB @ 1kHz, 1mW, or is it too powerful for that, and it would be smarter to get a lower powered dongle for the task?
My other alternative would be going to an Apple DAC for now, but since my main usage will be on a Desktop, the Apple adapter doesnt work too well, with the extremely short cable and such.
Edit: Just remembered I Have a Schiit Magni 2 Headphone Amp lying around. Would it work well with the E1DA 9038D as DAC, Magni2 as Headphone Amp for my Etymotic?
Thanks!
Doubt you'll get from here now. But from the E1DA site, 32 ohm and 10k ohm
Here's a hires version
Most portable amps can deliver much more power in balanced. For the record I have the A2 Noire's and E1DA 9038S and it's plenty of power.Thank you very much for tour answer.
I hope i'll find something else to drive it in single-ended (topping NX4 maybe? I dont know), as i tend to use less and less my fixed set (Topping D30 + Objective 2 DIY)
Well, since these measurements revealed some heavy channel imbalance, it would be nice if Amir could repeat them.Here you go: https://www.l7audiolab.com/f/fiio-ka3/
