Edit functions
rwortman
This forum seems to have odd editing behavior. When I reply to a post I often want to edit the quoted post to only include the comment I am replying to. Highlighting and deleting doesn’t work. Backspacing over things works but it is interminably slow. On every other forum I go to the backspace function deletes single characters for a few words and then switches to entire words to speed up the process. This one deletes single characters for a few words and then switches to deleting single characters only more slowly. What the hell?
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
You do know that you can select a part of a post to respond to, so you don't have to edit the entire post?
Not exactly your issue, but may help.
AdamG
Moderator
Reality
BDWoody
Chief Cat Herder
Moderator
Nice! Imagine how happy I am now, not knowing this myself beforehand. You just can’t, so don’t even try! :cool:
Sometimes, it's the small things...
I know how relieved I was when I first found that trick.
danadam
What operating system and browser are you using. Selecting and deleting works for me on linux on firefox. Also ctrl-backspace deletes to the beginning of the word and ctrl-shift-backspace deletes to to the beginning of the line. And of course there is "Toggle BB code" option (the icon with two square brackets), which should turn it into plain text input box.
But selecting what to reply for, mentioned above, seems the easiest.
R
rwortman
Mostly I am using IpadOS with Safari. I don’t see a control or alt key on the virtual keyboard. I guess I’ll do a bit of research. I figured that backspace behavior was a forum setting thst could be changed. The highlight and reply is news, I will try that. Editing my own verbosity is another matter.
Jimbob54
Long press hold on the start or end word then drag back (or forward) should do it
R
rwortman
I tried this on my Ipad and it doesn’t work. Maybe it’s a Safari thing or an IpadOS thing.
