EL DAC vs SMSL SU-8 vs Topping D50
Looking for a DAC in the $200-$300 dollar range. If it could be balanced that would be great. So far i'm deciding between these 3 DAC's (EL DAC vs SMSL SU-8 vs Topping D50). I'm going to be pairing it with either my Schiit Jotunheim or my Massdrop THX 789. Between these 3 DAC's which is best? Feel free to recommend any others within the given price range.
confucius_zero
I had that query once, they seem to measure marginally different to a negligible point.
Therefore, it's best to go with the one you're comfortable with: ergonomically, features wise, support wise, etc...
I just know I'm going for the EL DAC if I had the choice but D50 if that device had as good customer support as JDS since it has more features (filters etc...).
A
If they all sound about the same, then I guess i'm getting the SMSL since it's balanced and has a remote control....(remote control ftw). Thanks for the reply.
