Yes.Thank you for the answer! I don't use an equalizer when listening to music. Usually I listen to vocal jazz, instrumental music. Now I have a Fyne Audio F300, this acoustics with a narrow direction, if I move around the room (18 square meters) the sound changes. If I understood you correctly, the sound of Elac Debut Reference DBR-62 is natural and does not require a filter in comparison with Dali Oberon 3. Sorry, I speak Russian and write to you with the help of a google translator.
I found measurements for the bigger brother to your speaker Fyne Audio F301 (which has a larger woofer than F300, so it will have better bass extension and lower distortion). Multiple resonances are visible on the CSD graph #2. This speaker needs EQ to help it's performance.
Speaking of ELAC DBR62:
It has 80deg horizontal directivity, which means it has a wide listening spot and will sound great as you move around the room.
Take a look at this spreadsheet, click on "H Directivity PLOT" to understand how frequency will change as you move off-axis.
The Elac DBR62 would be a worthwhile upgrade from your current speakers.
