Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,237
- Likes
- 5,477
I see no discussion about them around here, are they that bad? Martin Logans look pretty cool.
No doubt someone here will come along shortly and inform us how poor they measure. But to my ears they sing and give me a wide open sense of sound that is captivating.
maybe time to start (trying to) describe the sound of electrostatics
If you want high volumes and/or pounding bass, then the 'stat is not for you. They're too delicate for that. I think one reason bass is anemic in 'stats because the speaker is free standing, the way a boxless woofer driver in the open would be. Cancellation severely attenuates the lows.
That may well be the reason why a 'stat panel is often paired with a woofer. The trick is to get the woofer and 'stat to blend together well around the crossover region.
Sure they look cool and sound good too.I see no discussion about them around here, are they that bad? Martin Logans look pretty cool.
They will measure terrible for sure. Mine fit your sound description as well. Reference sound though measured they will have a very poor rating.
Fortunately for me ratings mean nothing, actual sound does.
