GabrielPhoto
- Joined
- Jul 14, 2020
- Messages
- 403
- Likes
- 217
- Thread Starter
- #61
Is up to you. Do you like it then be happy with it. Personally I found it one of the worse centers I tested so far not only because of the very narrow horizontal dispersion but because it has like zero sound halo so I can never get the "ventriloquist effect" I value so much.Folks, my HT consists of C2+, LR T2+, and a bunch of A1s as sides and heights. C2+ is placed horizontally on monitor mounts and slightly tilted down, as it is right above the TV.
I can't hear C2+ difference from the 3 main positions on the couch, however, at the sides of the room it sounds not as loud, I guess that's the directivity.
Here's the question, shall I replace it with a better designed center speaker? The movies are watched on the couch only, will the SQ difference be noticeable at the sides/ off center mostly?
But in the end, the only thing that matters is what YOU prefer.
