Erratic & slow forum SW performance
Status
Not open for further replies.
Q
QMuse
I guess it would help narrowing stuff down. Creating a new user seems good suggestion to try narrowing down any corruption related to your user.. maybe try private browsing in addition to be sure.
It behaves the same in Chrome incognito window.
No..., Not strictly accurate lol
LOL
This strange behavior started few months ago. In that time I haven't created a new user. ;)
Blumlein 88
I use Chrome, Firefox, and Brave on phone, laptop using both Windows and Linux, Linux desktop and Macbook pro. No problems here or a couple other places I've used them.
Ever try using a VPN?
Martin
Cape Coral, FL
A problem affecting a single user is not a server side issue. You need to find out what is wrong in your configuration.
I have tried accessing the site, including hitting the reply button, on my home PC using Chrome, Edge and Firefox, from my IOS device using Safari, and from my work PC through a corporate firewall and proxy server also using Chrome, IE and Firefox. Works perfectly everywhere.
Are you sure you do not have some sort of malware that is inserting odd redirects?
Martin
I am sorry you are having problems. Smells like networking/firewall issue. Any chance of trying with the same hardware but using different network? Does it for example happen on your phone while using 4G rather than Wifi?
Q
QMuse
Thank you for taking your time trying to help with this issue. I tried using the same HW with different network and also using different HW with different network, so now I'm speculating my user data on the server somehow got corrupted. For that reason I tried to create a new user to test this. So far it works fine but I can't test it to full extent as it is waiting for post approval. User is "Olly" so maybe if you can approve post rights for it so I can test if that one would work well.. :)
P.S. Everything works fine when I'm not logged in so I don't think it is a FW/networking issue as logging in wouldn't make much difference to the systems dealing with lower OSI layers.
Q
QMuse
Martin
No, I don't use VPN to access Internet, and I'm also reasonably sure that my PC doesn't have any malware. As I said in my reply to @amirm, I'm quite sure my user data got corrupted on server as it works fine when I'm not logged in so lower OSI layers are excluded from this case.
I think the only way to confirm this theory is to try with another user so I'm waiting for this new user I created to be granted post credentials from the admin to test this.
D
Deleted member 65
Guest
Reinstall your PC.
Q
QMuse
Reinstall your PC.
As I already stated - I tried logging from another PC connected to another network and it showed the same problem, so I take it you're joking. How about you reinstall your PC, maybe that would help? :D
D
Deleted member 65
Guest
When you say ”another network” I assume network path is different from start to end, i.e PC/access point/switch/router/ISP is ”another network”. If so, then your problem is indeed beyond the ISP.
Q
QMuse
That is correct.
Not only that, but as I tried with another PC connected to another network it is also beyond my original PC.
Dialectic
a fortified compound
Zero problems on my 15-year-old POS Dell 32-bit laptop (aka the "Craptop") running Firefox under Ubuntu 16.04.6 LTS.
D
Deleted member 65
Guest
That is correct.
Right, can you outline your different networks in as much detail as you can. Any recent change in router firmware?
Just out of curiosity, which different ISP’s you’re using? Any of them are 4/5G networks? If so logging in from an iPad/iPhone/Android device yields the same result?
Q
QMuse
Scenario 1: PC1 --> over Wifi to router --> Eth to optic converter --> ISP1
Scenario 2: PC2 --> over Wifi to Android phone acting as a router --> 4G mobile data network --> ISP2
Lars, I was working as an IP Network Manager with Telco/ISP provider so trust me when I say this is not about network. I was also IT Manager with a few large companies so I'm pretty sure it's not about my original PC as well. ;)
D
Deleted member 65
Guest
Good, seems you’ve done your homework ... ;-)
Won’t go into my boring IT credentials ...
Sal1950
The Chicago Crusher
Central Fl
Q
QMuse
I think I know what's happened, @QMuse has quoted Floyd Toole's book so many times he's accidentally published the whole thing online and the ASR server copyright filter has identified this and is punishing him .
LOL
I would normally object vigorously to such false accusations, but..
Status
