Erratic & slow forum SW performance
Status
Not open for further replies.
gvl
SoCal
Maybe look at the page source and try to find where those bad URLs are, may give a clue why the forum spits them out, or not. Sounds like a forum bug to me.
Blumlein 88
Then why aren't the other users seeing the same problem?
Sal1950
The Chicago Crusher
Central Fl
gvl
SoCal
Maybe he is The One? If seriously no idea, something odd in his profile or server stored user forum data can be causing it.
thewas
Probably the reason is your audiophile rooter which is optimised more for a high end smooth sound rather than boring wooden ears tech text. :p
Better get a nerd-rooter for surfing here but don't forget to switch to your other one when listening to music, as it sounds very boring analytical and not musical at all. :p
Q
QMuse
When I log in as another user everything works fine. Interesting, isn't it..?
Soniclife
Try updating random fields on your profile, and see if the problem goes away. Overwriting dodgy data with clean data is probably the easiest way to fix it.
Q
QMuse
Good idea, but doesn't work..
D
Deleted member 65
Guest
If you haven’t tried already. Create a new Win10 user, login to your ASR acct thru this user.
Sal1950
The Chicago Crusher
Central Fl
Log out, clear all ASR cookies and and log in again.
Feargal
I had a quick try earlier with latest Chrome on Windows 10 (and Firefox) and I'm not getting any CORS errors in the debug console. I get just one error, which is for blocking https://www.googletagmanager.com/gtag/js , but that's usually from (I think) the uBlock Origin plugin (and intentionally blocked).
I don't understand why you're getting the CORS errors and I'm not. I don't have anything funky customised in the browser and I suspect you don't either. It's almost like you have a super strict mode enabled somehow.
Maybe first try disabling plugins, especially adblockers?
I'm wondering whether your DNS provider could be causing this but I don't really see how.
[edit] - a good test may be to try through a VPN connection. A good free one I use is Windscribe (10GB free a month), though others are available obviously. There's a plugin/addon for Chrome for Windscribe which works well. This would bypass any possible blocking which your ISP may be providing.
[edit2] - possibly your HTTP requests are running through a proxy? Could it be an antivirus acting as a local proxy? I see you have the problem on several computers so maybe the same antivirus on both?
Q
QMuse
I guess you guys missed the part where I said that the same problems appear on different computer and on Android phone, but everything works well when I log as another ASR user. IMO that points to corrupt user data on the forum server.
Thomas savage
The Watchman
uk, taunton
Those castle speakers gave you away , and your IP ha ha
But yes you never pretended, like sign up under a different name and hide your real identity.
Well , at some point you need to realise some folks know more than you think and they know it well before you could imagine but we are a forgiving bunch .. not without a sense of justice mind you ha ha
Q
QMuse
I could have easily skip mentioning my Castle speakers and hide my IP, but I chose not to.
Status
