For the noobs (not being Don and a few others
Yes, semantics. For me the differences are clear..
A to D conversions happens in the AD converter chip(s) and in the DA conversion chip the digital signal is converted back to analog.
Everything in between the A-D and D-A chip is 'digital' in nature and could be called 'data' or 'code' if you will.
For me code means something else.. it means 'a machine code program' to me so data for me.
In the 'digital' signal there is a lot of 'analog' happening such as 'cleaning' up signals and the PLL part.
So yes, there is analog happening in the digital realm to make it work.
The clock generator is analog (it is a neat sine wave) which is basically 'clipped' so it becomes more square-wave alike.
That clock is usually divided a couple of times as well.
Even though the clock is digital in nature and needed (essential) for everything to work I don't regard it as a digital signal. Some will though.
I would call the SPDIF signal 'digital' and consists of data + clock so transmissions are easily decoded and only 1 (signal) wire is needed.
Also I would call the L-R clock, and data digital.
A clock is a constant frequency and is not 'modulated'. It always has a 50% dutycycle (well... very close to it) so is not a 'digital signal' to me.
L-R clock, SPDIF and data all have a varying signal and is what I consider a 'digital signal' as it contains info about the 'enclosed information'.
The clock has no such information (aside from the speed)
Digital signals can be actual '0's and '1's but can also be just indicating transitions from 0 to 1 or 1 to 0. For the latter a synchronised clock is essential.
That clock tells you how many consecutive 0's (or 1's) are there after each other. Regardless if they are Eight to Forteen coded or not. Even if the 'digital data' were transmitted via 2 sinewaves of different frequencies which would be an analog transmission the signal itself still remains 'digital' in nature as it contains 'data' which in turn contains 'information.
Curious to hear what others find to be 'analog' or 'digital' and above all... why.
* Perhaps a mod could create another thread with all this non 'wire tester' related blabla or move that to another thread if it exists. *
The eye-pattern in a CD player (as described in the video) he considers 'analog' and the laser pre-amp he describes as an ADC.
Well.. the data coming of the eyepattern is 'digital' but the amplitude is used in an 'analog' way.
The laser tracking looks at the analog waveform (amplitude) and adjusts the tracking to keep it 'maximum' in output.
The disc speed is controlled by adjusting the speed so that the 'smallest' detected 'sinewave' is 3 clock pulses 'wide'
The eyepattern is made up of a series of 'transitions' from 0 to 1 or 1 to 0. The minimum width of a 'land' or 'pit' is 3T (3 clockpulses) and maximum 11T (11 clockpulses) and can be any width in between (in steps of 1 closck pulse width)
The pits and lands thus are not '1's and '0's as in the actual 'digital audio data'. That data (which contains the analog 'information') is enclosed in other data. This is needed to ensure small 'errors' on the disc or blemishes do not cause audio data to be corrupted.
Eight to Forteen modulation, interleaving and error correction as well as bit frames and other essential data is enclosed in the eye-pattern.
All this I call digital signals.
