Exasperating Server problem
Status
Not open for further replies.
Purité Audio
Industry Insider
Barrowmaster
London
I have been trialling a new server , it was designed to replace my MacBook but it keeps stuttering, dropping out ,constantly 'initialising ' but not always 'connecting' to Roon.
Every other Mac/PC/laptop works absolutely solidly in the very same configuration in my system.
I am just wondering if I am missing something or is the product just not well designed?
Any thoughts welcome.
Keith_W
Melbourne, Australia
Couple of questions for you.
1. Is it Windows or Mac?
2. How is it connected to your network? Ethernet or Wifi?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
It is Linux, it connects optically to a switch which is connected to my network, if I plug any other device into the switch via ethernet it works fine ,the server only has optical connection so I can't connect it any other way.
Keith_W
That's odd that your server only accepts optical. Have you tried another optical cable? Is there no way to try an Ethernet connection?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
It is very frustrating it was bought with an eye to recommend it to customers, but no one would buy it at the moment!
Especially when the cheapest laptop, works perfectly, table,connects instantly doesn't stutter ,drop out etc...
Apparently it is all my fault!
Thomas savage
The Watchman
uk, taunton
That old chestnut :D
Swiftly preceded by ' we've sold loads and never had any problems before' :rolleyes:
If it's optical only and 'plug n play' it literally can't be your fault...
Is it a uk brand or a little known Canadian guy?:D
When you say "optical" you mean a fiber connection? If so, that connection or cable can be faulty.
To test, get a cheap USB to Ethernet adapter and plug that in and see if that works. If it does, then rules out all but that fiber connection.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Amir Hi yes an optical connection , the Ethernet 'switch ' has the transmitter built in and the receiver is in the Streamer , the only connection 'in' to the Streamer is optical it has USB out.
What happens if you go on that server and try to access the Internet? Does it run reliably? Can you download a large file without problem?
Or is this a dedicated music server and you can't use it as a computer this way?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
It is a dedicated server, but if I connect any other computer to the ethernet switch ( wireless off ) everything works perfectly ,no stuttering ,dropouts everything fine.
I don't believe the optical transmission is the problem because it does work, but fitfully, stutters then drops out, or gets stuck 'initialising' , I am using it dedicated to Roon.
I realize the switch is OK. I am trying to diagnose what part of the server is at fault. If it is the optical cable, then that is an easy fix. Try the USB to Ethernet adapter in there and hopefully it has a plug-and-play driver and will recognize and use that (leave optical connection disconnected).
The problem you describe sounds very much like a faulty network connection and hence my reasoning above.
RayDunzl
Central Scrutinizer
Riverview FL
He said the USB on the mysterious and unidentified device is for output.
I have nothing optical here except S/PDIF.
Have you previously successfully used the optical port on the ethernet switch with some other device?
FrantzM
Could it be the driver on the Optical NIC?
Do you have to use Optical. Have you tried replacing the Optical NIC with a Copper one? Do you know Linux?
Keith_W
The fact that all other devices work off your switch suggests that it is a problem with one of the following:
1. The optical transmitter in your switch
2. The optical cable
3. The optical receiver in your server
4. Some other hardware or software fault with your server
To diagnose each of this, you need to:
1. Remove the server and plug another device which accepts optical input to the SAME output on your switch and the same cable. If it works, then the optical transmitter in your switch is OK.
2. Swap the optical cable
3. Try an Ethernet connection to your server. Or, as Amir suggests, try a USB to Ethernet connector.
4. Go to a friend's house and see if your server works on their network.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I tried again on another PC to download the upgraded OS , still can't download, despite any 'grade student' being able to do it.
The manufacturer isn't responding to my emails, I don't believe he has sent a micro SD card with the new OS. I am not sure why he wouldn't if the upgraded OS would solve problem?
I had an engineer friend install the unit into his system and he suffered from the very same issues.
Bit disappointing really, certainly couldn't recommend this product or the mnufacturer as things stand.
Thomas savage
The Watchman
uk, taunton
Come on Keith , it's 'plug and play'a true 'turn key' device ..Even the manufacturers 6 year old daughter can work it :D:D
Oh well I hope the issue 'blows itself out' :D
Though I know nothing about the server I think I can identify the 'real' problem ;):D
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The concept is great, I like everything about it, I just would like it to work as well as any cheap laptop.
Status
